Interfacing question of different voltage levels
  • Thread starter Thread starter Physicslearner500039
    Levels Voltage
The discussion centers on interfacing two hardware units with different voltage levels: Unit 1 operates at 5V TTL logic, while Unit 2 requires 24V for high detection. To connect Unit 1's digital outputs to Unit 2, the use of level shifting circuitry is necessary, with alternatives to costly 24V relays being sought. For interfacing Unit 1's inputs with Unit 2's outputs, the suggestion is to use resistors to convert the 24V signal to a 5V TTL level. Precautions must be taken to prevent damage to Unit 1's I/O when interfacing with the 24V system.
  • Understanding of TTL logic levels and interfacing techniques
  • Knowledge of voltage level shifting methods
  • Familiarity with resistor voltage divider circuits
  • Basic electronics components, including relays and pull-up resistors
  • Research voltage level shifting circuits for digital signals
  • Learn about resistor voltage dividers and their applications in interfacing
  • Explore alternatives to relays for digital signal interfacing
  • Review the SN7407 datasheet for insights on buffer circuits
Electronics engineers, hardware developers, and anyone involved in interfacing systems with differing voltage levels.
Hi all,
i have this small interfacing problem somebody please suggest me how to resolve this problem. i have two hardware boards say unit 1 and unit 2. The Unit 1 has 48 digital inputs and outputs configurable through software as either input/ouptut but they are ttl level i.e 5V logic. i have unit 2 which is also having digital input and outputs but this unit needs 24V to detect as high (internal to unit2 24v is converted into 5V and given to microcontroller) and on its output it gives either 24V or 0V. Now i need to interface this unit1 and unit2
My clarifications are:
1. To connect digital output of unit1 of 5V by level shifting to 24V and giving it to unit2. please suggest some intermediate circuitry for this
as per my idea i think i can use 24v relays but it would be costly and using some 32 24V relayes would be difficult. could somebody some altenative and easy solutions.
2. to interface the unit1 digital inputs with unit2 digital outputs. since unit1 recongnizes ttl levels can i convert the 24v high from unit2 by using resistors and bring it to 5V and connect to unit1. Please provide some ideas for this.
what are the possibilities in which the unit1 5V I/O may get damaged or what care i have to take while interfacing with 24V system.
please let me know if you have further clarifications.
thanks in advance,
regards,
satya
Thank you for the quick reply. i have drawn the internal diagrm of the Unit2 conversion from the 24V to 5V system and attched.
thanks and regards,
satya
19K
