Period of swing of a rope with two fixed ends
  • Context: Undergrad
  • Thread starter Thread starter derek88
    Period Rope Swing
The discussion revolves around calculating the period of swing for a rope fixed at both ends, similar to a playground swing. Participants explore the implications of the rope's configuration on its swinging motion, contrasting it with a simple pendulum scenario.
  • One participant notes that for a simple pendulum, the period is given by T = 2*pi*(L/g)^0.5, but questions how this applies when both ends of the rope are fixed.
  • Another participant cautions that the formula for the period of a simple pendulum cannot be directly applied to a rope with distributed mass, emphasizing the need to consider the center of mass and rotational inertia.
  • A later reply mentions that the term inside the square root for a uniform rod should be 2L/3 instead of L/2, suggesting a correction to earlier assumptions.
  • One participant suggests that to find the moment of inertia for the swinging rope, one must integrate the square of the distance from the axis of rotation, indicating a more complex calculation involving torque and angular acceleration.
Participants express differing views on how to approach the problem, with no consensus on the correct method for calculating the period of swing for the rope fixed at both ends. The discussion remains unresolved regarding the application of pendulum formulas to this scenario.
Participants highlight the importance of considering the rope's mass distribution and the need for integrating to find the moment of inertia, indicating that assumptions about the rope's behavior may vary based on its configuration.
derek88
Friends:
If you take a rope and fix the top end and allow the rope to swing, then it is just a pendulum and the period of swing is widely known (and on wikipedia) as approx. T = 2*pi*(L/g)^0.5 where L is the length of the pendulum and g is gravity.
My question is: What if I take both ends of the rope and fix them (like tying them to an overhead horizontal metal bar), like a playground swing. How do you calculate the period of swing then? In this case the "length of the pendulum" would vary - it would go from 0 at the fixed ends to the maximum at the saggiest part of the rope.
This problem seems really simple but I can't figure it out! Any help would be greatly appreciated. Thanks a lot!
You need to be careful using the equation
T = 2pi (l/g)^0.5
if you have a rope (or a rod) on it's own then l is the distance to the centre of mass of the rope or rod (l/2 if uniform).
In a simple pendulum it is assumed that the string has zero mass.
Hope this helps with your rope fixed at both ends (l/4 ?)
Careful. Whenever you have a distributed mass acting as a pendulum, you cannot use that simple formula. The period of such a 'physical pendulum' (as opposed to a 'simple pendulum') depends on the rotational inertia as well as the distance of the center of mass to the pivot. (It's not enough to just replace L by L/2.)
Again, this must be treated as a physical pendulum. You'll need to know the rotational inertia and the location of the center of mass.
See: Physical Pendulum
Doc Al
I have looked up your reference and it works out that the term inside the square root is 2L/3
Not L/2 for a uniform rod.
Thank you for picking that up.
You'll need to find the moment of inertia about the axis joining the two ends of the rope, this means integrating the square of the distance of each part of the rope from this axis over the length of the rope (along the curve it makes which is a catenary). From this you solve
[tex]\tau = -I\alpha[/tex]
Where [itex]\tau[/itex] is the torque on the system, [itex]I[/itex] is the moment of inertia and [/itex]\alpha[/itex] is the second derivative of the angle made between the vector of the center of mass of the rope relative to a plane which lies along the line of the axis of the swinging rope and is perpendicular to the ground.
  • · Replies 23 ·
  • · Replies 51 ·
