Work and conservation of energy
The discussion focuses on applying the principles of work and conservation of energy to a roller coaster problem involving initial speed, friction, and height. The initial speed at point A is 1.76 m/s, and the average force of friction is one-fifth of the weight. The correct equation to use is 1/2mvi^2 + mgh - 1/5mgd = 1/2mvf^2, where the mass cancels out. The participant is advised to double-check calculations, ensure consistent units, and verify the accuracy of the values used in the equation.
  • Understanding of basic physics concepts such as work and energy
  • Familiarity with the equations of motion and forces
  • Knowledge of frictional forces and their impact on motion
  • Ability to perform unit conversions and dimensional analysis
  • Review the principles of conservation of energy in mechanical systems
  • Study the effects of friction on motion and energy loss
  • Practice solving problems involving roller coasters and energy transformations
  • Learn about the role of gravitational potential energy in motion
Students studying physics, educators teaching mechanics, and anyone interested in understanding energy conservation in real-world applications.
jbot2222
okay i applied work and conservation of energy to this problem, but the solution doenst come out right! :mad:
Suppose the roller coaster in the figure below passes point A with a speed of 1.76 m/s
If the average force of friction is equal to one fifth of its weight, with what speed will it reach point B? The distance traveled is 45.8 m and h = 29.4 m.
1/2mvi^2 + mgh - 1/5md = 1/2mvf^2
the m's cancel out and u should be able to solve for Vf, but it doest come out right!
First your equation is wrong, because it says the force of friction is [itex]\frac{1}{5}[/itex] of its weight, so [itex]F_{f} = \frac{1}{5}mg[/itex] and the work done by friction [itex]W_{f} = - \frac{1}{5}mgd[/itex]
It's great that you applied the concepts of work and conservation of energy to this problem. However, it's important to double-check your calculations to ensure that you have the correct answer. In this case, it seems like there may be an error in your equation or calculation. Make sure you are using the correct values for mass, initial velocity, and height. Also, check your units to ensure they are consistent and that you are using the correct formula for work and conservation of energy. If you are still having trouble, don't hesitate to ask for help from a teacher or classmate. Remember, it's important to check your work and make sure you have the correct solution. Keep practicing and you will improve your problem-solving skills.
  • · Replies 20 ·
