Variable Frequency Generator question
The discussion focuses on creating a variable frequency generator to achieve specific resonant frequencies for experimental purposes, such as breaking objects like wine glasses. Users suggest utilizing variable frequency audio oscillators, which are available as kitsets for under AU/US$150, capable of producing frequencies from a few hundred Hz to 30 kHz. Additionally, it is essential to amplify the audio signal using an audio power amplifier to generate sufficient output levels. A calibrated dB level meter is recommended for experimenting with the audio levels required to induce vibrations and shatter objects.
  • Understanding of variable frequency audio oscillators
  • Knowledge of audio power amplifiers
  • Familiarity with using a calibrated dB level meter
  • Basic skills in audio editing software, such as Audacity
  • Research variable frequency audio oscillators and their specifications
  • Learn about audio power amplifier selection and usage
  • Explore the functionality of calibrated dB level meters for audio experiments
  • Investigate audio editing techniques in Audacity for frequency control
This discussion is beneficial for hobbyists, audio engineers, and experimenters interested in resonance phenomena, sound generation, and practical applications of audio technology.
Thundagere
As you can probably guess by my last few posts, I'm looking into resonance right now. I thought it would be interesting to make a device that could hit a specific resonant frequency, maybe even smash an object. Sure, people have done it, but...fun :)
Anyhow, I was looking on how to make one. Could I simply take an old set frequency generator (say, 10 KHz) and add a potentiometer in? THen just drill a hole, and you can twiddle it down and up.
Otherwise, I'm not sure how to construct one. How could I produce the vibrations necessary—and more important, control their frequency—for a relatively low price?
dunno what country you are in. ?
Variable frequency audio oscillators are relatively readily available even as kitsets for under AU/US$150 that go from a few 100's of Hz to up to 20 - 30 kHz
If you are looking at breaking things with resonance you will discover that it is not just being able to attain the resonant freq of the object ( say a wine glass) you will also need to feed the audio signal into an audio power amplifier to get some significant level out.
With a calibrated dB level meter you could then do some experiments to determine the audio level needed to just make the object vibrate and the level needed to make it shatter
cheers
Dave
cheers
Dave
United States, so I could probably buy one.
Could I use Audacity to generate the sound, and jack it to a good speaker? If I could control the frequency of the sound by editing it, and use the speaker to amplify it, could I maybe get some noticeable vibration out then?
