How Do Reflection and Curvature Affect Images in Optics?
  • Thread starter Thread starter jlmac2001
    Couple Optics
The discussion focuses on the effects of reflection and curvature on images in optics, specifically using a brass ball as an example. When standing 5 feet away from a 1-foot diameter brass ball, an inverted, real image of the pawn shop is observed due to the reflection of light off the ball's curved surface. To calculate the radius of curvature, the formula 1/f = 1/u + 1/v is utilized, where the object distance is 100 mm and the magnification is 0.037X, resulting in a calculated radius of curvature of 2703.7 mm.
  • Understanding of basic optics principles, including reflection and image formation.
  • Familiarity with the mirror formula: 1/f = 1/s' + 1/s.
  • Knowledge of magnification calculations: m = -s'/s.
  • Ability to interpret and draw ray diagrams for curved mirrors.
  • Study the properties of convex mirrors and their applications in optics.
  • Learn how to derive and apply the mirror formula in various scenarios.
  • Explore the concept of focal length and its significance in image formation.
  • Investigate the relationship between object distance, image distance, and magnification in optical systems.
Students of physics, optical engineers, and anyone interested in understanding the principles of image formation through curved mirrors.
jlmac2001
1. Imagine that you are standing 5 ft from and looking directly toward, a brass ball 1 foot in diameterhanging in front of a pawn shop. Describe the image you would see in the ball.
-Would I have to find the an answer that tells me that it is inverted, real, virtual, etc?
2. What formula would I useto find the radius of curvature? if the magnification of a keratometer is found to be 0.037X when the object distance is se at 100 mm, what is the radius of curvature?
Mirror problems are a little difficult to do in a forum. It really helps to have a picture. I highly suggest you do a google search on convex mirrors and look at the examples done in your physics book. For this types of problems DRAW A PICTURE and make sure you label everything
The equation you would use is
1/s' + 1/s = 1/f where 1/f = 2/R
R is the radius of curvature
f is the focus
s is the distance from your eye to the front of the mirror
s' is the distance from the front of the mirror to the image (may it be real or virtual)
m = -s'/s where m is the magnification
1. If you are standing 5 ft away from a brass ball with a diameter of 1 foot, you would see an inverted, real image of the pawn shop in the ball. This is because the light from the pawn shop is reflected off the curved surface of the ball and forms an image on the opposite side of the ball. The size of the image would depend on the curvature of the ball and the distance between you and the ball.
2. To find the radius of curvature, you can use the formula 1/f = 1/u + 1/v, where f is the focal length, u is the object distance, and v is the image distance. In this case, the object distance is 100 mm and the magnification is 0.037X, so the image distance can be calculated by v = u/m = 100 mm/0.037 = 2703.7 mm. Then, using the formula, 1/f = 1/100 mm + 1/2703.7 mm = 0.0003709 mm^-1. Therefore, the radius of curvature would be r = 1/f = 2703.7 mm.
