C++: Understanding exit() in Sample Code
  • Context: C/C++
  • Thread starter Thread starter Saladsamurai
The discussion revolves around the use of the C++ function exit() in a sample code snippet, particularly focusing on its behavior compared to return() within the context of program termination and error handling. Participants explore the implications of using different exit codes and the effects on program execution and debugging.
  • One participant expresses confusion about the behavior of exit(1) compared to return(0), noting that the executable does not stop entirely and requires manual intervention to stop it.
  • Another participant explains that exit(1) terminates the program and returns an exit code that can be used by shell scripts to determine the success or failure of the program.
  • Some participants clarify that there is no significant difference between return i; and exit(i); when used in main(), but there are important differences when exit() is called from other functions.
  • One participant mentions that using exit(0) behaves differently in terms of the debugging interface, suggesting that it does not trigger the same debugging response as exit(1).
  • Another participant notes that returning a non-zero exit code generally indicates an error, which can affect how scripts interact with the program.
  • There is a discussion about the differences between abort() and exit(), highlighting that abort() causes abnormal termination while exit() leads to normal termination, even if unsuccessful.
  • One participant points out that the behavior of exit() is defined by the C standard, which ensures that open files are closed and streams are flushed upon termination.
Participants express differing views on the implications of using exit() versus return(), particularly regarding program termination and debugging. There is no consensus on the best practices for using these functions in various contexts.
Some participants mention that the behavior of the debugger and the program's exit status can vary based on the operating system and the specific development environment being used.
Readers interested in C++ programming, particularly those dealing with program termination, error handling, and debugging practices.
Saladsamurai
In a sample code that I have, we use the the following snippet to test whether a file has opened properly:
Code:
if (inputFile.fail())
		cerr << "Error opening input file...check that file\n "
		"exists and is in current program directory. \n";
		[B]exit(1)[/B];
The exit(1) is confusing me a little bit. I was under the impression that this acts the same way that return(0) does. But upon running it, there are apparently some differences. I am pretty new to this stuff, but it appears that when I use exit(1) the running of the executable does not stop entirely? If I want to run it again, I have to use the 'stop' button first (which implies there is something still running).
Can someone tell me if I am using exit() properly here? Thank you. :smile:
Technology news on Phys.org
exit(1) stops the program (buffers flushed, connections closed... program terminated but not always)
and the program will return an exit code of 1 that a shell script can interogate and decide what to do which is usualy to print a message to the user and stop.
Basically the value used as an argument to the exit() call is returned as a exit code to the shell script.
see: http://www.cplusplus.com/reference/clibrary/cstdlib/exit/
On Linux/Unix... bash shell... the command:
echo 'exit-code=' $?
will show you the value of the exit-code of the last command executed.
see: http://tldp.org/LDP/abs/html/exit-status.html
for WINDOWS/DOS: you'd use
echo Exit Code is %errorlevel%
or
if errorlevel 1 (
more details here for windows shell scripts:
http://stackoverflow.com/questions/...ication-exit-code-from-a-windows-command-line
or
if errorlevel 1 (
Nice documentation link :!) for linux/unix. Thanks (I'm on a Mac)!
I changed my code to exit(0) and it does what I think I want it to be doing.
The C++ standard library works the same way on any operating system (well, it SHOULD work the same way ...)
There is no real difference between return i; and exit(i); if you use them inside main().
There is a big difference if you call exit(i); within any other function. Your program stops execution immediately, and never "returns" from the call to exit.
Of course if your program detects some error condition and there is no sensible way to recover from it, an "instant stop" can be exactly what you want to do.
Try something like this:
Code:
#include <whatever you need to make it compile on your system>
void mysub()
    cout << "hello\n";
    exit(1);
int main()
   mysub();
   cout << "goodbye\n";
   return 0;
and then replace exit(1); with return; and see the difference.
</snip>
Hi AlphaZero :smile:
What I was getting at was this: If you look at my console in the following screenshot, the big red stop sign is available for me to stop something when I use exit(1). If I use exit0, it is not avai;able for me.
The big red stop sign is not available for you to stop anything. There's nothing to stop. It is there for you to examine the non-zero exit status.
Hi D H :smile:
So, when I click on the stop sign, I am not presented with any 'examination' options. It simply says kill in the Console and says 'Debugging Terminated' which sure sounds like something is being stopped:confused:
Apparently, the console is going into some kind of debug mode after receiving an error code. Returning anything but 0 is generally considered by the shell to indicate an error. As in, "return 1;" or "exit(1);" are considered to indicate the occurrence of an error. When you use "exit(0)" it means there was no error.
Essentially, you are ending your program after an error and not even informing the user that there was an error. This is bad for a couple reasons; the most important of which is that, if a script is using your program and your program fails because of an error, that script will continue to execute as if your program had done what it was supposed to do.
Just noticed: At the bottom of the console, it says "GDB: Debugging terminated." GDB is a debugger that is used to inspect a running (or stopped) program to see what caused a problem. When your program tries to abort using "exit(1)," something makes GDB start debugging your program.
Also, you may want to use "abort();" a function that does the same thing as exit(1) and return 1, but is more explicit.
abort and exit are very different functions. abort causes abnormal termination while exit causes normal termination. If the argument to exit is non-zero the termination is still "normal," it is however unsuccessful. There's a world of difference between abnormal termination and normal but unsuccessful termination.
From the C standard, 7.19.3 (Files) ¶5:
If the main function returns to its original caller, or if the exit function is called, all open files are closed (hence all output streams are flushed) before program termination. Other paths to program termination, such as calling the abort function, need not close all files properly.​
In any implementation that complies with the standard, exit must call must about call functions registered with atexit, flush and close any open streams, and unlink files created with tmpfile. None of these behaviors is required for abort. On a Unix-compliant system, abort does flush and close any open streams, but this is not required by the standard.
On a Unix-compliant system, abort will raise the signal SIGABRT. The default signal handler for SIGABRT drops a core file and terminates with abnormal status given by the SIGABRT signal number.
The return status from a program on a Unix-compliant system comprises two bytes. One byte contains the termination signal (one bit of which indicates whether a core file was generated). The other byte contains the exit status in the case of normal termination .
Saladsamurai said:
Hi D H :smile:
The debugger is still running. The application is not. It's some (mis)interaction between the graphical debugger you are using with Xcode and the debugger gdb proper.
D H, AlphaZero, TylerH, and jedishrfu:
Thanks for all of your contributions. :smile: I am slowly getting better at this with your help. Thanks again!
-Saladsamurai
  • · Replies 0 ·
11K
