New Reply
LARGE Water Body
Share Thread Thread Tools
Jan3-12, 01:37 PM   #1
LARGE Water Body
We have heard of celestial bodies, but who heard of a large Water Body(made only of water)?
Considering that the water will not convert into other chemicals under pressure and enclosing it in a box full of 1 atm air and 300 K, How large/massful/volume should the water body be to get 9.81 m/s^2 at its surface?
Consider:
- Surface Tension
- Gravitation Force
- Atmospheric Pressure
- Any other cohesive forces
- Made of H2O, for H2O, and by H2O
- If there is a variation in density, it is uniformally distributed through the body.
I have tried to derive the formula for a given 'g', but the gravitational force and surface tension has to be considered for a pirticular 'area' and not a 'mass' to get the contraction/expansion of the water body.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Study provides better understanding of water's freezing behavior at nanoscale
>> Soft matter offers new ways to study how ordered materials arrange themselves
>> Making quantum encryption practical
Jan4-12, 06:14 AM   #2
xts
You may neglect surface tension and similar forces. It counts for few milimeter droplets, but not for a large body.
If your body is not rotating (or the rotation is slow), you may assume spherical symmetry.
You may probably assume that the density [itex]\rho [/itex] is uniform.
So now the gravity on the surface is given as
$$g(r) = \frac{4}{3}\pi \,r^3 \rho\cdot \frac{G}{r^2} = \frac{4\pi}{3}\,G\,\rho\, r$$
If you want to include the change of density with pressure you must write appropriate integrational equation and solve it, but as the [itex]\rho(P)[/itex] is nonlinear, it might be pretty difficult - you must use probably some iterative method or compute it numerically.
Jan4-12, 07:01 AM   #3
D H
Mentor
Quote by xts View Post
That's not a good assumption for large solid bodies, let alone a large liquid one. Iron is a lot less compressible than is water, yet the density of the Earth's (mostly) iron core is 13.088 gm/cm3. Compare that to the density of iron at STP, 7.874 gm/cm3.
Jan11-12, 12:23 PM   #4
LARGE Water Body
That is exactly why i came here to ask =D, I was unable to make a proper integral equation, =( .
And, if we do not consider the ρ to be uniform throughout the body at any instant, then the way to get to the answer will become much more complicated.
And, density of the Earth varies with depth around many conditions and effects, as its not made of the same material. Here, we are considering that excessive pressure on water molecules down deep wont make different compounds.
Jan11-12, 06:34 PM   #5
D H
Mentor
You cannot with any validity assume that density for a "LARGE water body" (your words) will be uniform. Water is much more compressible than is iron, and a ball of solid iron at the center of the Earth is compressed to 3/5 its vacuum density due to the weight of the mass above it.
Jan12-12, 10:13 AM   #6
D H
Mentor
Quote by D H View Post
Sorry about the bad wording. I meant iron is compressed to 3/5 of its uncompressed volume (or 5/3 its uncompressed density).
Jan12-12, 12:18 PM   #7
This formula is right.
It makes radius of earth would be around 35 Km with all water mass.
Almost 6 times larger than the current radius.
Is it physically possible to have all liquid mass no rocky core?
Jan12-12, 05:47 PM   #8
Recognitions:
Gold Membership Gold Member
Could you be sure that there would be no drastic molecular change near the centre under that pressure? (Or perhaps that's what's implied at the end of the previous post.)
Jan12-12, 05:51 PM   #9
Quote by sophiecentaur View Post
I remembered something about water at very high pressures but can't find a source other than wiki, the new scientist link doesn't work unless you're a subscriber.
At high temperatures and pressures, such as in the interior of giant planets, it is argued that water exists as ionic water in which the molecules break down into a soup of hydrogen and oxygen ions, and at even higher pressures as superionic water in which the oxygen crystallises but the hydrogen ions float around freely within the oxygen lattice.
I can't find any reference to how high a pressure if needed though.
Jan13-12, 04:41 AM   #10
Uhh, if we consider the 'practicality' of stuff, such as dissoctiation of h2o at high pressures, variation in density, etc. etc. etc. then please do derive the answer using the same, =D
Cos, in the short sight, if we consider too many stuff, we will get too complicated of an answer.
Jan13-12, 05:35 AM   #11
Recognitions:
This thread needs some ground rules. Are we dealing with an incompressibke fluid (I.e. total theory) or a half way house involving the 'linear' modulus of water OR are we attempting to go further? We need to decide. There's no point arguing between different standpoints.
Jan13-12, 07:07 AM   #12
For an incompressible fluid, we already have the answer:
For a compressible fluid with uniform density we dont, that is what this thread is about.
Once we get the above answer, only then we can talk about density variation and chemical changes. Its better to go step by step from rudimentary to advanced.
So, can somebody give me an idea who/what to integrate for compressible fluid with uniform density.
And we are considering bulk modulus. So, there will be a change in radius.
Jan13-12, 07:28 AM   #13
D H
Mentor
Hydrostatic equilibrium, [itex]\partial \rho/\partial r = -\rho g[/itex].
Jan13-12, 07:49 AM   #14
Recognitions:
Quote by Algren View Post
If it compressible then its density won't be uniform. You probably know that but what do you mean here?
It strikes me that you could look at the equations for a gas atmosphere (and the derivations used) and find a way to include modulus in the formula.
Jan13-12, 12:30 PM   #15
There is a difference between uniform density and constant density.
Uniform, i.e. if the liquid collapses, its net density increase uniformly everywhere, hence density is uniform. Its not like earth, where we have varying densities as we go deep.
Isnt that for a liquid column? its straight from ρgh=P. I thought PA= - B x ΔV/V will be used.
Jan13-12, 01:20 PM   #16
Recognitions:
"its net density increase uniformly everywhere"??
I think you mean its modulus is uniform or the substance is the same throughout. Uniform means the same everywhere and its density wouldn't be. It would increase in density towards the centre - which is not what 'uniform' means'.
Jan13-12, 03:44 PM   #17
The bulk modulus of water is needed to determine the variation in density with pressure, but it says nothing about how that pressure comes about. Think about a ball of water, consider a cylindrical section of it that passes through the center and has an arbitrarily small radius. The pressure must be distributed such that it is equal at every distance from the center (but will vary with said distance), this is Pascal's law (it also follows from the fact that we are considering fluid in equilibrium). Therefore, there are no forces on the column other than its own weight. So, the pressure at any given point in the ball must be the sum of the external pressure and the integral version for the pressure due to a column of water (since both g and ρ vary with distance from the center).
Quote by rollcast View Post
Wikipedia links to a page with lots of information and diagrams on the properties of water. I also found a NIST webpage that gives lots of information (link to page where one can get the variation of density with pressure up to 10000bar (1GPa) at a given temperature).
It turns out that the water in the central regions of the ball turns into a high pressure form of ice (ice IV assuming the ball is isothermal at 300K) long before the ball is massive enough to have a surface gravity of 9.81m/s2 (at least according to my preliminary calculations and what I have heard on TV). I am getting values of between ~2229Km and ~2360Km for the minimum radius to produce ice (assuming it forms at about 9500bar, the corresponding surface gravities are: 0.697 to 0.709m/s2), depending on the value of the compressibility I use (assuming it is constant, the larger value corresponding to one that interpolates between the minimum and maximum densities, the smaller to that which obtains at everyday pressures). I might be able to extend this analysis to the necessary ball masses if I knew how we wanted to treat the density above 1GPa, for which I don't have any quantitative data (though I expect it exists somewhere on the internet).
New Reply
Tags
acceleration, gravitaional force, gravity, tough, water body
Thread Tools
Similar Threads for: LARGE Water Body
Thread Forum Replies
How Do Large Water Reservoirs Effect The Length of the Day Introductory Physics Homework 12
How Do Large Water Reservoirs Effect The Length of the Day Introductory Physics Homework 0
What accounts for the large shadows cast by the ends of the thin legs of the water st Introductory Physics Homework 5
water in body Medical Sciences 19
Acoustic Resonance in large water filled pipes Classical Physics 0
