New Reply
Increase in weight if an object is illuminated
Share Thread Thread Tools
Jan3-12, 03:11 PM   #1
Are there experiments which show that the weight of a body, with initial mass between 1 g and 1 kg, really increases if illuminated for a certain time?
Photons have energy E = hf but no mass. If the weight of a body gets bigger after being radiated with light it means that energy indeed converts to mass.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jan3-12, 03:19 PM   #2
Recognitions:
Heating the body up would have more effect than simply illuminating. However I doubt if the weight gain cold be measured.
Jan3-12, 05:50 PM   #3
Quote by mathman View Post
Heating the body up...I doubt if the weight gain cold be measured.
I saw what you did there!
Are you wearing a Freudian slip?
Jan3-12, 10:40 PM   #4
Cavendish's equipment was remarkably sensitive for its time. The force involved in twisting the torsion balance was very small, 1.74 x 10^–7 N, about 1/50,000,000 of the weight of the small balls or roughly the weight of a large grain of sand.
http://en.wikipedia.org/wiki/Cavendish_experiment
Raising the temperature of an object (increasing its heat energy) increases its mass. For example, consider the world's primary mass standard for the kilogram, made of platinum/iridium. If its temperature is allowed to change by 1°C, its mass will change by 1.5 picograms (1 pg = 1 × 10^−12 g).
http://en.wikipedia.org/wiki/Mass%E2...gy_equivalence
F = 1.74 * 10^–7 N is the weight of a mass m = 1.77 * 10^–8 g = 17.7 ng (measured by Cavendish in 1797).
1 kg heated to 1000 degree, using laser light, will increase its mass by 1.5 ng (I guess).
If Cavendish was able to detect forces as small as 17.7 ngf, more than 200 years ago, maybe an increase in mass of 1.5 ng can be measured today with enough precision. I do not know, this is just a question.
New Reply
Thread Tools
Similar Threads for: Increase in weight if an object is illuminated
Thread Forum Replies
How much does your Weight increase when you running at a certain speed? and how muc Advanced Physics Homework 1
Does lifting an object higher increase its potential energy? Classical Physics 12
Increase in spin rate as object collases to black hole Special & General Relativity 4
Quick question: If a car speed increases, does its weight increase or decrease? Introductory Physics Homework 3
Weight of object Introductory Physics Homework 2
