Derive \dot v: A Thermo Relation for V, m and v
  • Context: Graduate
  • Thread starter Thread starter An1MuS
    Derivative
The discussion focuses on deriving the time derivative of specific volume, represented as v = V/m, where V is volume and m is mass. The user seeks to understand the expression for the derivative of specific volume, denoted as \dot v. The application of the quotient rule is confirmed, leading to the formula \dot v = (m \dot V - V \dot m) / m², which is essential for analyzing mass and volumetric flow in thermodynamic systems.
  • Understanding of thermodynamics, specifically the concepts of volume (V), mass (m), and specific volume (v).
  • Familiarity with calculus, particularly the quotient rule for derivatives.
  • Knowledge of mass flow rate (\dot m) and volumetric flow rate (\dot V) in open systems.
  • Basic principles of fluid dynamics as they relate to thermodynamic systems.
  • Study the application of the quotient rule in calculus to reinforce understanding of derivatives.
  • Research specific volume calculations in thermodynamic systems to understand practical applications.
  • Explore mass and volumetric flow rate equations in open systems for a comprehensive grasp of fluid dynamics.
  • Investigate advanced thermodynamic relations and their implications in engineering contexts.
This discussion is beneficial for students and professionals in thermodynamics, mechanical engineers, and anyone involved in fluid dynamics and system analysis in open systems.
An1MuS
I'd like to know the result of deriving both sides of the equation in respect to time
[itex]v= \frac {V}{m}[/itex]
[itex]\frac {d}{dt}v=( \frac {d}{dt}) \frac {V}{m}[/itex]
which gives
[itex]\dot v = . . . ?[/itex]
If you want some backup, this is a very common thermodynamics relation, where V = volume, m = mass and v = specific volume [m3/kg]. In open systems, we want to know mass flow and volumetric flow so we get [itex]\dot m[/itex] [kg/s] and [itex]\dot V[/itex] [m3/s]. I'd like to know if there's such a thing about specific volume as well, and that depends on how you do that derivative.
Best wishes and thanks,
An1MuS
The quotient rule applies: dv/dt = {mdV/dt - Vdm/dt}/m2
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 0 ·
