Thermodynamics problem help again
  • Thread starter Thread starter Enoch
    Thermodynamics
The discussion centers on calculating the heat transfer required to raise the temperature of 4.22 moles of helium gas from 314 K to 531 K during an isochoric process. The molar specific heat of helium at constant volume is 12.5 J/K mol. The initial calculation of heat transfer (Q) was incorrectly computed as 2712.5 J because the number of moles was not factored into the equation. The correct calculation should be Q = Cn(Tf - Ti) = 12.5 J/K mol * 4.22 mol * (531 K - 314 K), resulting in a total heat transfer of 11463.5 J.
  • Understanding of isochoric processes in thermodynamics
  • Familiarity with the concept of molar specific heat
  • Basic knowledge of the first law of thermodynamics
  • Ability to perform calculations involving temperature changes and heat transfer
  • Study the first law of thermodynamics in detail
  • Learn about isochoric and isothermal processes
  • Practice calculations involving molar specific heat and heat transfer
  • Explore the properties of helium gas and its behavior under different thermal conditions
Students studying thermodynamics, physics educators, and anyone looking to deepen their understanding of heat transfer in gases.
Enoch
Sorry for the second question in just a day, but my proffessor really didn't cover this material very well. Thanks for any help given :).
A cylinder contains 4.22 mol of helium gas at a temperature of 314 K. The molar specific heat of helium at constant volume is 12.5 J/K mol. How much heat must be transferred to the gas to increase its temperature to 531 K if it is heated at a constant volume? Answer in units of J.
Well, after reading the problem, I knew that it was an Isochoric Thermal process due to the comment "heated at a constant volume". Therefore this equation applies:
Change in Internal Energy = Q - W
- The work is going to be 0 joules
- Amended equation: Change in internal Energy = Q
Q = Cn(Tf - Ti)
- Solving for that: Q = (12.5)(531 - 314) = 2712.5
I plugged that in as my answer, and it was wrong. Where did I go wrong? Is the problem even setup right from my perspective?
Q = Cn(Tf - Ti)
Brilliantly,up until the final calculation.U forgot to multiply by the number of moles of He.Your result should ve been 4.22 times larger.It's awkward,because u stated the formula right. :wink:
Again, thanks very much.
  • · Replies 17 ·
