What Are the Answers to These Challenging Physics Multiple Choice Questions?
  • Thread starter Thread starter Sombra
    Choice Physics
This discussion addresses three challenging physics multiple-choice questions related to thermodynamics and electromagnetism. The efficiency of a Carnot engine increases to 75% when the hot reservoir temperature is doubled, calculated using the Carnot efficiency formula: efficiency = (T(h)-T(c))/T(h) x 100%. The direction of the electric field between two potentials (+50V and +100V) is from Y to X, with a strength of 100 V/cm, determined by the formula E = V/d. Lastly, the de Broglie wavelength is inversely proportional to the square root of kinetic energy, expressed as λ = h/p, where p is momentum.
  • Carnot efficiency formula
  • Electric field strength calculation (E = V/d)
  • De Broglie wavelength equation (λ = h/p)
  • Understanding of kinetic energy and momentum relationships
  • Study the Carnot efficiency and its applications in thermodynamics
  • Learn about electric fields and potential differences in electromagnetism
  • Explore the de Broglie wavelength and its implications in quantum mechanics
  • Investigate the relationship between kinetic energy and momentum in classical physics
Students of physics, educators preparing for exams, and anyone seeking to deepen their understanding of thermodynamics and electromagnetism concepts.
Sombra
Physics Questions (mult choice!)
These questions confuse me:
1. A heat engine operates in a Carnot cycle b/w two reservoirs, a hot reservoir at temperature T(h) and a cold reservoir at T(c). The efficiency of the engine is 50%. The temperature of the hot reservoir is increased to 2T(h). The efficiency of the engine now is--- a. 25% b. 33% c. 75% and d. 100%. (If you know of at least an equation I could use, it would be great. I ruled out 100% since it's not really possible, but I really don;t know)
2. Line X has a potential of +50V and line Y has a potential of +100V. The distance between X and Y is 2.0 cm. Which of the following gives the direction of the electric field and its strength? a. X to Y, 25 V/cm b. X to Y, 100 c. Y to X, 25 d. Y to X 100. (I have no idea how to approach this.)
3. The de Broglie wavelength of a particle that has kinetic energy E(k) is lamda. The wavelength lamda is proportial to: a. E(k) b. 1/E(k) c. 1/ square root of E(k) d. E(k)^2. (I said E(k) because they said that E(k) was lamda, but I don't know)
Thanks!
3. The De Broglie wavelength is
[tex]\lambda = \frac{h}{p}[/tex]
where h is a constant of proportionality and p is the momentum mv of the particle.
The problem will be solved if we can express p in terms of the kinetic energy E(k) (what is this weird notation?!)
[tex]E(k) = \frac{1}{2}mv^2 = \frac{1}{2}\frac{m^2v^2}{m} = \frac{1}{2}\frac{p^2}{m} \Leftrightarrow p^2 = 2mE(k) \Leftrightarrow p = \pm\sqrt{2mE(k)}[/tex]
So
[tex]\lambda = \frac{h}{\pm\sqrt{2mE(k)}} = \frac{\pm h}{\sqrt{2m}}\frac{1}{\sqrt{E(k)}}[/tex]
i.e. the answer is c.
1. The correct answer is c. 75%. The equation to use here is the Carnot efficiency formula: efficiency = (T(h)-T(c))/T(h) x 100%. When the temperature of the hot reservoir is increased to 2T(h), the efficiency becomes (2T(h)-T(c))/2T(h) x 100%, which simplifies to 75%.
2. The correct answer is d. Y to X, 100. The direction of the electric field is from positive to negative, so it goes from Y to X. The strength of the electric field can be calculated using the equation E = V/d, where V is the potential difference between X and Y and d is the distance between them. Plug in the given values, and you will get 100 V/cm.
3. The correct answer is c. 1/ square root of E(k). The de Broglie wavelength is given by the equation lamda = h/p, where h is Planck's constant and p is the momentum of the particle. Since kinetic energy is proportional to momentum, the wavelength is proportional to the inverse of the square root of kinetic energy.
