New Reply
Calculating wall's behavior at object impact
Share Thread Thread Tools
Jan5-12, 10:04 AM   #1
Hello and thank you for reading my question. I am attempting to calculate what effect on a wall has an impact (a car impact or as in my theoretical calculations a punch) of an object into it. With effect I mean how strong impacts can a wall a, survive and b, stay undamaged. Since car crashes deal with too great numbers I have chosen as an example for calculations a punch Known data:
a = 9 m/s2
v = 7 m/s
m = 4 kg
Ek = 98 J
S (impact area) = 60 cm2
Wall thickness = 10 cm
2. Relevant equations
F = ma
Ek = 1/2 mv2
P = F/A
a = 1/2 S/t2
3. The attempt at a solution
I have gathered a large ammount of data on concrete, brick, steel and mortar strength and fatigue limit. From what I know F = ma is only valid for stationary objects (like the force of me standing on a floor) but not for impacts. I calculated the kinetic energy of the punch but I don't know how to calculate the Force of the impact from it. Also, are the Force and the following pressure and stress from the force the only factors relevant in such an impact into a wall?
Another problem is that while I know how to calculate surface pressure of the impact, I don't know how to calculate internal stress. The equations are Fx/S, but I don't know how to acquire either of these variables. I also don't know what kind of stress a punch (or car crash) is, is it shear stress or flexural stress?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jan5-12, 03:09 PM   #2
To calculate Force in an impact you need to use:
Force = rate of change in MOMENTUM
You need to have some idea of the time duration of the impact and also whether the impact is elastic or ineleastic.
As an example, your 4kg moving at 7m/s has momentum of 28Ns.
If the collision lasts for 0.1 secs and the collision is inelastic then the rate of change in momentum is 28/0.1 = 280N.... this is the force due to the collision.
Hope this helps
Jan10-12, 11:51 AM   #3
Thank you very much. It helped me a lot. Now that I know the force I only need to learn how to calculate internal stress in the wall.
Btw, one small question, by duration of the impact you mean how long the hand or the car stays touching the wall, right?
New Reply
Thread Tools
Similar Threads for: Calculating wall's behavior at object impact
Thread Forum Replies
Impact of a cannonball on a brick wall General Physics 10
retarding force, freely moving object, impact stationary object, rest without rebound Engineering, Comp Sci, & Technology Homework 2
Calculating the forces in a dropped object's impact Introductory Physics Homework 1
Object against wall with horizontal force acting on wall Introductory Physics Homework 5
Impact of a car on a wall General Physics 20
