New Reply
Lie Derivatives and Parallel Transport
Share Thread Thread Tools
Jan8-12, 04:15 PM   #1
Hi, I've begun learning about General Relativity, though I've already had some exposure to differential geometry.
In particular, I understand that Lie Differentiation is a more "primitive" process than Covariant Differentiation (in that the latter requires some sort of connection).
My question is this: parallel transport can be used to understand how a vector changes when you drag in along a curve on a certain surface. To be sure, you institute local coordinates, compute the metric, and then the connection (here, the connection being used, in this coordinate basis, are the Christoffel symbols), and then solve the differential equation.
In this way, you can find out, for instance, how much the vector changes its direction under a certain curve. But, is this information only encoded in the connection? That is to say, to find out how much the vector deviates, must I employ parallel transport, or is there some procedure, using only Lie Derivatives, to examine the change?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jan8-12, 07:04 PM   #2
Recognitions:
Lie derivatives also define a sort of transport. However, the covariant derivative does not depend on objects outside the curve, while the Lie derivative does. So in Lie transport, the curve must be specified as an integral curve of a vector field.
Jan9-12, 10:23 AM   #3
Recognitions:
The absolute derivative of a vector uμalong a curve with tangent vector vμ is uμvν (this is zero for parallel transport), whereas the Lie derivative along the same curve is uμvν - vμuν.
I think what you mean by "outside the curve" is that the Lie derivative depends on the gradient of v, not just v itself.
Jan9-12, 01:13 PM   #4
Recognitions:
Quote by Bill_K View Post
Yes, so v must be a vector field, and not just the tangent vector to a curve.
Jan9-12, 09:44 PM   #5
Oh, I know that much. My main concern is calculating angular deviation from using Lie derivatives.
I tried this: I begin with a vector A, and there are points P, and Q. They are connected by a curve Y, parametrized by an affine parameter t, whose tangent vector is u = dY(t)/dt. Using the pullback on the isomorphism generated by u, I take the vector from P to Q. Then, I use the metric at P to find <A(Q), u(Q)>. I compare this with <A(P), u(P)>. Given affine parametrization, u does not change under parallel transport, so I think this would be accurate.
EDIT: I am a little bit querulous about my last assumption there, and am examining it now.
New Reply
Tags
christoffel, connection, curvature, holonomy, lie derivative
Thread Tools
Similar Threads for: Lie Derivatives and Parallel Transport
Thread Forum Replies
Parallel transport Special & General Relativity 14
Parallel Transport Advanced Physics Homework 3
Parallel Transport Special & General Relativity 20
parallel transport Introductory Physics Homework 0
Lie transport vs. parallel transport Differential Geometry 10
