How Do You Calculate the Final Velocity of a Car on a Curved Track?
  • Thread starter Thread starter HawKMX2004
    Track Velocity
The discussion focuses on calculating the final velocity of a car moving down a curved track, factoring in centripetal acceleration and friction. Key equations include Vf = (Distance / Time) + Vi^2 / Radius for final velocity and IE = mgh + 1/2mv^2 - Heat loss to Friction for initial velocity. To find the radius of the curve, the formula R = V^2 / a is essential. The heat loss due to friction can be calculated using the work done by friction, W = Fd, where F is the force of friction and d is the distance traveled.
  • Understanding of centripetal acceleration and its formula, a = V^2 / R
  • Knowledge of conservation of energy principles in physics
  • Familiarity with the concept of friction and its impact on motion
  • Basic algebra skills for rearranging equations
  • Research how to calculate centripetal acceleration in different scenarios
  • Study the conservation of energy in mechanical systems
  • Learn about the factors affecting friction and how to calculate it
  • Explore practical examples of motion on curved tracks in physics
Students studying physics, particularly those focusing on mechanics, automotive engineers, and anyone interested in understanding the dynamics of vehicles on curved tracks.
HawKMX2004
Im Having problems with 2D- curved track velocities. The question is...Find an Equation to find the velocity final of a car with mass - m going down a curved track with a coefficient of Friction - Uk The track is height - h above the ground and has an initial Velocity of Vi...so basically how do you find the velocity of a car moving down a curved track with centripetal acceleration factored in.
Heres my start...I need a lot of HELP please.
I don't know radius and distance is the length of the curved section of the track...any help on finding radius? I'd really appreciate it
The other question i had trouble with..is Find an equation for the Initial velocity at each point ( the beginning of each section ) for the same track with same mass - m and same height - h and same coefficient of friction - Uk ...
My start...I don't get this at all please help..
I don't know the heat loss to friction..could you help me there please? with an equation or anything? I am very confused...please help, I want to try and get this finished for tomorrow
Finding the velocity of a car on a curved track with centripetal acceleration can be a bit tricky, but there are a few equations that can help you solve for the final velocity. The first equation you mentioned, Vf = (Distance / Time) + Vi^2 / Radius, is a good starting point. However, as you mentioned, you will need to know the radius of the curved section of the track in order to use this equation. To find the radius, you can use the formula for centripetal acceleration, a = V^2 / R, where a is the centripetal acceleration, V is the velocity, and R is the radius. Rearranging this equation, you can solve for R as R = V^2 / a. Once you have the radius, you can plug it into the first equation to solve for the final velocity.
For the second question about finding the initial velocity at each point on the track, you can use the conservation of energy principle. This principle states that the total energy of a system remains constant. In this case, the initial energy (IE) of the car at each point on the track will be equal to the sum of its potential energy (mgh) and its kinetic energy (1/2mv^2), minus any energy lost due to friction. You can then rearrange the equation to solve for the initial velocity at each point, giving you an equation like this: Vi = sqrt(2IE/m - 2gh). Again, you will need to know the radius of the track in order to solve for the initial velocity at each point.
In terms of the heat loss to friction, this can be a bit more challenging to calculate as it depends on various factors such as the type of surface the car is moving on, the speed of the car, and the coefficient of friction. One approach you can take is to use the equation for work done by friction, W = Fd, where W is the work done, F is the force of friction, and d is the distance traveled. You can then use this equation to calculate the work done by friction at each point on the track and subtract it from the initial energy to find the final energy.
I hope this helps and good luck with your assignment! It may also be helpful to consult with your teacher or classmates for further clarification or assistance.
  • · Replies 16 ·
18K
  • · Replies 97 ·
20K
