Greens Theorem: Evaluate Line Integral of 6xy-y^2
The discussion revolves around applying Green's Theorem to evaluate a line integral of the form \(\oint_{C} (6xy - y^2) dx\), where \(C\) is oriented counterclockwise and bounded by the curves \(y = x^2\) and \(y = x\). Participants are exploring the setup and calculation of the integral, including the correct interpretation of the curves and the limits of integration.
  • Participants discuss the correct formulation of the line integral and the area integral derived from Green's Theorem. There are questions about the limits of integration and whether the initial calculations are correct. Some participants suggest that the integral may need to be split due to the curves intersecting.
The discussion is active, with participants questioning the correctness of the initial setup and calculations. Some guidance has been provided regarding the need to specify the problem accurately and to consider the limits of integration carefully. There is no explicit consensus, but several lines of reasoning are being explored.
There are indications of typos in the expressions used, and participants are clarifying the correct forms. The discussion also touches on the necessity of evaluating the integral in different ways and whether changing the order of integration would yield different results.
bugatti79
Use greens theorem to evaluate this line integral [itex]\oint_{C} 6xy- y^2[/itex] assuming C is oriented counter clockwise. The region bounded by the curves y=x^2 and y=x.
[itex]\displaystyle \int\int_{R}\Bigl( \frac{\partial Q}{\partial x} - \frac{\partial P}{\partial y}\Biggr) = \oint_{C} Pdx + Qdy[/itex]
I calculate
[itex]\displaystyle \oint_{C} 6xy- y^2 dx= \int_{0}^{1} \int_{x^2}^{ \sqrt x} (-6x+2y)dy dx[/itex]
This correct start?
I calculate
This correct start?
You need to specify the problem correctly. In other words, don't omit stuff. This expression doesn't make sense as written:
$$\oint_{C} 6xy- y^2$$
If [tex]\int_{C} -3x^{2}dy-y^{2}dx[/tex] as the integral representation, then -6x+2y is totally valid.
Sorry, that was a typo but I had it correct further on.
[itex]\displaystyle \oint_{C} 6xy- y^2 dx[/itex]
Hence is my calculation in post 1 correct?
You mean
$$\oint_{C} (6xy- y^2) dx.$$
The limits on your area integral are wrong.
vela said:
You mean
I calculate
This correct start?
Sorry, that sqrt was a typo. It should read...
[itex]\displaystyle \oint_{C} (6xy- y^2) dx= \int_{0}^{1} \int_{x^2}^{ x} (-6x+2y)dy dx[/itex]...good to go?
Yes, that looks right. You could always check by evaluating the integrals both ways.
but how would you evaluate the LHS of above if we don't have the limits for the LHS?
the LHS is a line intergal, and you are given the curves, so you should be able to subtitute y(x) into the integral and evaluate to the endpoint of the curve
In this case it will require splitting the integral into 2 parts, with one for each curve, and the endpoints will be where the curves intersect
for more info see wiki
http://en.wikipedia.org/wiki/Green's_theorem
Ok. I calculated line integral (LHS) which involved 2 integrals and then summing them.
Now I am to evalute the following by changing dx to dy. Should I expect a different answer?
Now for [itex]\displaystyle \oint_{C} (6xy- y^2) dy= \int_{0}^{1} \int_{x^2}^{ x} 6y dy dx=\frac{2}{5}[/itex]...?
what do you think?
(PS not trying to be smart, but its worth you trying to think things through)
lanedance said:
what do you think?
Part of me thinks that the answers should be the same because we are calculating the area of the bounded region so it doesn't matter what direction we integrate along...?
