Verifying Solution to DEQ: y = e^{3x}cos(2x)
  • Thread starter Thread starter QuarkCharmer
The function y = e3xcos(2x) is a solution to the differential equation y'' - 6y' + 13y = 0. The confusion regarding linearity arises from a misunderstanding of the term "linear" in the context of differential equations. The linearity of the differential equation pertains to the operator acting on y, not the form of the function itself. The operator is linear as long as y and its derivatives appear only to the first power, which is satisfied in this case.
  • Understanding of second-order linear differential equations
  • Familiarity with derivatives and their applications
  • Knowledge of linear operators in differential equations
  • Basic concepts of linear algebra
  • Study the properties of linear operators in differential equations
  • Learn how to verify solutions to second-order linear differential equations
  • Explore the method of undetermined coefficients for solving differential equations
  • Investigate the role of initial conditions in the context of differential equations
Students studying differential equations, mathematicians interested in linear algebra applications, and educators teaching concepts of linearity in mathematical functions.
QuarkCharmer
Verify that the indicated function is a solution to the differential equation. Assume an appropriate interval I of definition for each solution.
[tex]y'' - 6y' +13y = 0[/tex]
[tex]y = e^{3x}cos(2x)[/tex]
Well, I started taking derivatives to see if y was indeed a solution, but that got rather complicated fast for what is some of the first problem sets from day 1 of class. I believe that this is NOT a solution because of the cosine, which would indicate that y(x) is not a linear function clearly. Since the DEQ is linear of the second order, I assume that the solution will be linear as well?
Frankly, I am confused on when to consider a function linear. Does the dependent variable have to be linear, or is it the independent variable that matters? What if I replaced cos(2x) in the above equation with cos(2y).
Is this the correct manner of thinking on this problem? (ie: see cosine, must not be correct)
it is the solution to the homogeneous diff equ. Linear means that none of the terms are of some power like squared.
I think you need to recalibrate your sense of what qualifies as complicated. :wink:
No, that's not correct.
You're not interested in whether a function is linear here. You want to know if an operator is linear. The equation you have can be written in the form ##\mathcal{L}y = f(x)##, where ##\mathcal{L}## is an operator acting on y. If the operator is linear, it has the properties
\begin{align*}
\mathcal{L}(y_1 + y_2) &= \mathcal{L}y_1 + \mathcal{L}y_2 \\
\mathcal{L}(cy) &= c\mathcal{L}y
\end{align*}and the concepts from linear algebra can be applied to solve the equation.
To determine if the operator ##\mathcal{L}## is linear, you just need to make sure that y and its derivatives, if they appear, are only taken to the first power, which is indeed the case here.
  • · Replies 18 ·
