What is a Constant? Explained in Simple Terms
  • Context: High School
  • Thread starter Thread starter rishch
    Constant
The discussion revolves around the concept of a constant, exploring its definition and implications in both mathematics and physics. Participants seek to clarify what constitutes a constant, how it is used in equations, and the context-dependent nature of the term.
  • Some participants define a constant as a number that does not change and has a set value, citing examples like pi, i, and e.
  • Others suggest that constants can act as "fudge factors" in equations, such as setting c = 1 in E = mc² to simplify calculations.
  • One participant emphasizes that the meaning of "constant" can vary between mathematics and physics, noting that in physics, a constant describes a quantity that remains unchanged regardless of the system's conditions.
  • Another participant discusses the concept of a constant of proportionality, explaining that it remains the same across different applications, such as in the equation F = kma.
  • It is noted that a constant can also refer to a specific value in a particular context, such as constant acceleration in a given situation, without implying that it applies universally.
Participants express differing views on the definition and implications of constants, indicating that multiple competing interpretations exist. The discussion remains unresolved regarding the broader implications of constants across different fields.
Participants highlight that the term "constant" may have different meanings depending on the context, and there is an acknowledgment of the potential for confusion between mathematical and physical interpretations.
rishch
Could someone please explain the concept of a constant in simple terms?
It is a number that simply does not change and has a set, defined value. Pi, i (squareroot of -1) and e (Euler's number) are all examples of constants.
It's also a "fudge factor" so that our equations work out. For example, we all know E = mc2, but many physicists set c = 1 so that E = m and the fudge factor disappears. I've often wondered if it was possible to develop a mathematical/physical system where all of the fudge factors for the fundamental constants of the universe could be eliminated, but my mathematical expertise is nowhere near that sophisticated.
It depends on the context. The word "constant" have connected but different meanings in maths and in physics. As you're posting in the physics forum, I guess you're more interested with the physics notion. In a physical theory a constant is a quantity used to describe the behaviour of a system (together with plenty of other quantities) but that does not depend on which system is studied, what are its environement, the interval of time considered or the position in space of the system. So its value can be given (whithin a given system of units) independently of any experience.
By a constant i was referring to this type of constant-
F is proportional to m
F is proportional to a
Therefore F=kma
where k is the constant of proportionality
In this case "k is a constant" means that k is a number, whose value does not depend on the mass, acceleration, force or any other physical properties of the system. I.e. whatever you apply it to, "k" will have the same value always (if you found it to be 2 by some experiment, for example, you could write F = 2ma).
Note that another "kind" of constant is for example where we take F = ma, and I say "a car is moving along a road with constant acceleration". In that case, I mean that a has some specific value which will not change in this specific situation that I am considering - obviously I don't mean that the car can never have another acceleration, nor that all the other objects in the universe must have the same value of a.
9K
  • · Replies 16 ·
