What are the Inverses of y=x^{2}+4x-6?
The problem involves finding the inverses of the quadratic function y=x²+4x-6 and determining the domains that yield these inverses.
  • Participants discuss rewriting the function and applying the quadratic formula to find the inverses. There are attempts to manipulate the equation and questions about how to proceed after obtaining certain forms. Some participants express uncertainty about the next steps and the implications of the quadratic nature of the function.
There is an ongoing exploration of the quadratic function and its inverses. Some participants have made progress in applying the quadratic formula, while others are questioning the need to restrict the domain to ensure the inverses are functions. The discussion reflects a mix of attempts and clarifications without reaching a definitive conclusion.
Participants note the importance of domain restrictions for the inverses to be valid functions, and there is mention of the graphical representation of the functions and their inverses.
crybllrd
The function
[itex]y=x^{2}+4x-6[/itex]
has two inverses. What are they and which domains lead to these inverses?
[itex]x=y^{2}+4y-6[/itex]
[itex]y(y+4)=x+6[/itex]
Not really sure where to go from here.
crybllrd said:
The function
Write this equation as x2 + 4x - 6 - y = 0, and solve for x using the quadratic formula. That will give you x = f-1(y) (with some abuse of notation as f-1 is not a function).
This is no help at all.
That's similar to being asked to solve the quadratic
[tex]x^2+2x=3[/tex]
and then taking the next step as follows, and getting stuck
[tex]x(x+2)=3[/tex]
You need to factorize! Or if you can't, which will be the case if you have a number such as, say, 4 instead of the 3, then you need to use the quadratic formula. If the 3 is replaced with a constant or variable, such as
[tex]x^2+2x=k[/tex]
then you definitely need to use the quadratic formula, applying all the same rules you know, but simply extending it to the realm outside of mere known constants.
OK, I got it from here I believe. I'm on mobile, so I will work it out when I get home and post my answer.
Alright, so I used the following for the quadratic formula:
[itex]a=1, b=4, and, c=(-6-y)[/itex]
to get
[itex]x=-2\pm2\sqrt{10+y}[/itex]
That will give you x = f[itex]^{-1}[/itex](y)
At this point, would I swap x and y to get the inverse of f(x)?
to get
Nearly, it should be
[tex]x=-2\pm\sqrt{10+y}[/tex]
because when you factorize the 4 out of the surd, you need to take the root of that so what you would've had was
[tex]x=\frac{-4\pm\sqrt{4^2+4(6+y)}}{2}[/tex]
[tex]x=\frac{-4\pm\sqrt{4(4+(6+y))}}{2}[/tex]
[tex]x=\frac{-4\pm\sqrt{4}\sqrt{4+(6+y)}}{2}[/tex]
[tex]x=\frac{-4\pm2\sqrt{4+(6+y)}}{2}[/tex]
Yes but the inverse needs to be a function, and you can't possibly have that with a [itex]\pm[/itex] there. You need to restrict the domain of your original quadratic for there to be an inverse that's 1:1.
OK, thank you.
I did have the quadratic right, I just typed it wrong.
I split it up into two functions from the +/-.
When I graph them, however, it does not look like it is mirrored over y=x.
EDIT: I figured it out, I didn't cancel out the 2 in the numerator.
All is well,
thanks again everyone~
  • · Replies 19 ·
