Determining Final Velocities in Multi-Collision System
  • Thread starter Thread starter Soaring Crane
    Collisions Momentum
The discussion revolves around a multi-collision system involving three masses: a 3 kg mass colliding with a 5 kg mass, which subsequently collides with a 4 kg mass. Participants are tasked with determining the final velocities and angles of each mass after the collisions, while also considering whether the collisions are elastic or inelastic.
  • Mixed
  • Participants explore the use of momentum conservation equations for both collisions, questioning the correct application of angles and signs in their calculations.
  • Some participants express confusion about whether to treat the collisions separately or collectively when assessing elasticity.
  • There are inquiries about the correct angles to use for the second collision and how to approach the kinetic energy calculations.
Participants are actively engaging with the problem, sharing their attempts and reasoning. Some have provided hints and suggestions for drawing diagrams to clarify the angles involved. There is a recognition that each collision needs to be analyzed separately, and while some guidance has been offered, there is no explicit consensus on the correctness of the calculations presented.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. The discussion reflects uncertainty about the assumptions regarding the nature of the collisions and the conservation of kinetic energy.
Soaring Crane
A 3 kg mass moving laterally at 5 m/s collides with a 5 kg mass at rest. As a result the 5 kg mass travels at 2 m/s at a 26 angle counterclockwise from the direction of the motion of the initial mass. The 5 kg mass then collides with a 4 kg mass at rest. The 4 kg mass then leaves at 1 m/s at a 30 angle counterclockwise from the direction of motion of the 5 kg mass.
a. Find the final magnitude and direction for the velocity of each of the first 2 two masses.
Does this apply to only the 3 kg and 5 kg mass?
Let us say m1 = 3 kg, m2 = 5 kg, m3 = 4 kg.
Now I am a bit confused since 3 masses and not 2 are involved.
This is how I started:
1st scene
x component: m1v1 = m1v1'*cos(0) + m2v2'*cos(26)
y component: 0 = m1v1'*sin(0) + m2v2'*sin(26)
But I am not sure if my signs are correct. Then from here I was going to add the 2 equations together to determine v1' and then use substitution for v2' . . .
The 2nd scene with m2 and m3 has stumped me. Do I use similar equations like those above but just replace it with the new velocity of m2 (v2' will be v2 now?) and angles (26 for m2 and 30 for m3)?
b. Are these collisions elastic? Why or why not?
Do I count all the collisions separately or will they all be elastic or inelastic?
Basically I have to see if kinetic energy is conserved by calculating the total KE after the collision(s) and comparing it with before the collision(s). But I don't know what to do from here because a collsion follows another collision, and I am totally lost.
Thanks for the help.
Try to do a drawing and put the collisions drawing up the angles, this may help you.
Yes - you should change the velocity - v2 = v2' do not change the angle for mass 2 to 26 - treat it as another collision.
Are there any hints to help me out on the kinetic energy portion?
Since you are given the final velocity of the 4 kg mass--no point in asking for that! :smile:
Just do it step by step.
1st scene
I assume you mean that m1 moves at some angle [itex]\theta[/itex], not 0!
You can work with the signs you chose. (Your angle will come out negative.) Hint: Isolate the m1v1' terms so you can solve for the angle.
Do the same analysis for the 2nd collision. (Draw a picture to keep the angles straight.)
Each collision must be analyzed separately.
Right. That's all there is to it. Since you already know the speeds before and after each collision (from part a), this part should be easy.
For angle 1, is it around 19? For the second collision, do I solve for angle 2 (so this is why I do not use 26)?
As for the actual equation is y-comp: 0 = m2v2'*cos(theta_2) + m3v3'*cos(30)?
Tell me if I'm wrong so I can amend it. Thanks.
Not according to my calculation.
Since you need to find the direction, of course you need to find angle 2. I would measure the angle from the direction of the incoming particle (just like you did for the first collision), so I would not use 26 degrees in the momentum equation. (Although in presenting your final answer for the direction of the velocity, you may need to make use of that 26 degrees.)
Looks fine to me.
For the 1st part:
0 = m1v1'*sin(theta_1) + m2v2'*sin(26)
-[(m2v2'*sin(26)]/[m1v1'] = sin(theta_1)
theta_1 = -17
Now v1' = [m1v1 - m2v2'*cos(26)]/[m1cos(-17)] = 2.1 m/s
2nd part:
0 = m2v2'*sin(theta_2) + m3v3'*sin(30)
-[m3v3'*sin(30)]/[m2v2'] = sin(theta_2)
theta_2 = -11.54 = -12
v2' = [m2v2 - m3v3'*cos(30)]/[m2cos(-12)] = 1.3 m/s
Wrong or right? Please check. Thanks.
Soaring Crane said:
For the 1st part:
theta_1 = -17
Incorrect. Since v1' is unknown, this equation not allow you to solve for theta_1. (I assume you got your answer by using v1 instead of v1'.)
To solve for the angle you need to combine both equations. See my hint in post #4.
  • · Replies 16 ·
