Projectile motion: solving for variable angle
The discussion revolves around solving for the launch angle θ of a projectile that must hit a specific target point (x, H) after being launched from the origin with an initial velocity V_i. The focus is on deriving an explicit formula for θ based on the given parameters, while navigating the complexities of projectile motion equations.
  • One participant outlines the problem and presents equations for vertical and horizontal motion, seeking a formula for θ in terms of V_i, x, H, and g.
  • Another participant suggests eliminating time t from the equations to derive a direct relationship involving θ, proposing to express cos(θ) in terms of tan(θ).
  • A participant acknowledges the suggestion and reformulates the problem, resulting in a new equation involving tan(θ) but struggles to simplify it further using trigonometric identities.
  • One participant mentions using WolframAlpha to solve for θ and notes that the solution provided by the tool was labeled 'incorrect', despite their own tests yielding consistent values for θ.
Participants express differing approaches to the problem, with no consensus on a definitive method or solution for deriving θ. There is acknowledgment of the complexity involved, and some participants question the validity of solutions obtained through computational tools.
The discussion highlights the challenges of simplifying trigonometric expressions and the potential discrepancies between analytical and computational solutions. There are unresolved mathematical steps and assumptions regarding the projectile's motion and the conditions for hitting the target.
foo_daemon
Hi,
I've been muddling over this problem for a few days. I thought there would be a simple approach, but I'm having trouble reaching a solution. Here is the rundown:
We have a 2D projectile launcher. It hurls an object from the origin (0,0) at some initial velocity with magnitude [itex]V_i[/itex] at angle θ with respect to the ground. You will be given its initial velocity, and must choose the launch angle θ such that the projectile will hit a target at point x,H (that is, a point x distance away with height H) during its descent (i.e. anytime after the peak where [itex]V_y = 0[/itex] ). It is a reasonable assumption that θ will be in the range [itex]0 \leq θ \leq \frac{\pi}{2}[/itex].
I am trying to find an explicit formula for θ in terms of [itex]V_i[/itex] , [itex]x[/itex] , [itex]H[/itex], and the usual [itex]g = -9.8 \frac{m}{s^2}[/itex]
[itex]V_{yi} = sin \theta V_i[/itex]
[itex]V_{xi} = cos \theta V_i[/itex]
We have the following solutions for t:
[itex]V_{yi} t + \frac{1}{2} g t^2 -H = 0[/itex]
[itex]V_{xi} t - x = 0[/itex]
Since we want the projectile to hit the point (x,H) at the same time, we set the equations equal to each other:
[itex]\frac {1}{2}g t^2 + ( V_{yi} - V_{xi} ) t + (x - H) = 0[/itex]
Use the quadratic formula to find t. (I expanded [itex]V_{xi}[/itex] and [itex]V_{yi}[/itex] in the resulting formula so we have θ back in the equation ).
[itex]t = \frac{-V_i ( sin \theta - cos \theta ) \pm \sqrt{{V_i}^2 ( 1 - sin{2 \theta} ) - 2 g (x - H)}}{g}[/itex]
I used trig substitution in the square-root to make a [itex]sin^2 + cos^2 = 1[/itex] and double angle formula for [itex]2 sin( \theta ) cos ( \theta ) = sin( 2 \theta )[/itex] .
I want to factor that nasty expression under the radical by 'completing the square', but I don't see how that is possible.
Also, I don't really want to solve for t ... that is, I don't care how long the projectile takes. All I care about is what angle it needs to be launched at so that it hits point (x,H) .
If you don't need t, then why solve for it?
You can eliminate t between the two equations and find an equation in the variable theta.
For example, find t from the second one and plug it into the first one.
Then you can write the cos in terms of tan and find a quadratic equation in tan(theta).
Aha... yes, I didn't really want to solve for t, I just didn't see a way around it. Your approach is simple, and I'm dumbfounded I didn't realize it first ;)
However, it still seems to be an involved problem. Now we have:
[itex]t = \frac{x}{V_0}[/itex]
Plugging this t into the formula for [itex]V_y[/itex], I get:
[itex]tan ( \theta ) x + \frac{ g x^2 }{2 cos^2 ( \theta ) V_0^2 } - H = 0[/itex]
This is very close to an explicit formula for θ, but I can't find any trig identities that will help me simplify. I can convert the [itex]\frac{1}{cos^2}[/itex] into [itex]sec^2[/itex] , but... that doesn't really seem to help.
1/cos^2=1+tan^2
Hm, I still had problems finding the solution. I 'cheated' and used WolframAlpha to solve that last formula for theta.
Wolfram uses substitution and gives:
[itex]\theta = tan^{-1} \left ( \frac{ -V_i^2 \pm \sqrt{-g^2 x^2 + 2 g H V_i^2 + V_i^4}}{gx} \right )[/itex]
WolframAlpha then states that after plugging the substitution back into the formula and running a check, it determines this solution is 'incorrect'. I plugged in some test numbers a few times, and the value for theta appears correct (consistent).
  • · Replies 18 ·
