DivGradCurl
- 364
Any help is highly appreciated.
Thank you
Problem
[tex]y^{\prime \prime} = xy[/tex]
My Solution
If
[tex]y = \sum _{n=0} ^{\infty} c_n x^n \Longrightarrow xy = \sum _{n=0} ^{\infty} c_n x^{n+1} = \sum _{n=1} ^{\infty} c_{n-1} x^n[/tex]
and
[tex]y^{\prime \prime} = \sum _{n=2} ^{\infty} \left( n-1 \right) n c_n x^{n-2} = \sum _{n=0} ^{\infty} \left( n+1 \right) \left( n+2 \right) c_{n+2} x^{n}[/tex]
Then
[tex]\sum _{n=0} ^{\infty} \left( n+1 \right) \left( n+2 \right) c_{n+2} x^{n} = \sum _{n=1} ^{\infty} c_{n-1} x^n[/tex]
Hence, we may find the recursion relation
[tex]c_{n+2} = \frac{c_{n-1}}{\left( n+1 \right) \left( n+2 \right)} \qquad n=1,2,3,\ldots[/tex]
and so we have:
[tex]c_0[/tex]
[tex]c_1[/tex]
[tex]c_2[/tex]
[tex]c_3 = \frac{c_0}{2\cdot 3}[/tex]
[tex]c_4 = \frac{c_1}{3\cdot 4}[/tex]
[tex]c_5 = \frac{c_2}{4\cdot 5}[/tex]
[tex]c_6 = \frac{c_3}{5\cdot 6} = \frac{c_0}{2\cdot 3\cdot 5\cdot 6}[/tex]
[tex]c_7 = \frac{c_4}{6\cdot 7} = \frac{c_1}{3\cdot 4\cdot 6\cdot 7}[/tex]
[tex]c_8 = \frac{c_5}{7\cdot 8} = \frac{c_2}{4\cdot 5\cdot 7\cdot 8}[/tex]
[tex]\vdots[/tex]
Well, since this is a second-degree differential equation, we must have [tex]c_2 = 0[/tex]. It also follows that
[tex]c_{3n} = \frac{c_0}{2\cdot 3\cdot 5\cdot 6\cdot \cdots \cdot \left( 3n -1 \right) \left( 3n \right)} \qquad n=1,2,3,\ldots[/tex]
and
[tex]c_{3n+1} = \frac{c_1}{3\cdot 4\cdot 6\cdot 7\cdot \cdots \cdot \left( 3n \right) \left( 3n +1 \right)} \qquad n=1,2,3,\ldots[/tex]
Therefore
[tex]y = c_0 + c_1 x + c_0 \sum_{n=1} ^{\infty} \left[ \frac{x^{3n}}{2\cdot 3\cdot 5\cdot 6\cdot \cdots \cdot \left( 3n -1 \right) \left( 3n \right)} \right] + c_1 \sum_{n=1} ^{\infty} \left[ \frac{x^{3n+1}}{3\cdot 4\cdot 6\cdot 7\cdot \cdots \cdot \left( 3n \right) \left( 3n +1 \right)} \right][/tex]
Questions
1. Have I got it right?
2. If so, can I write the denominators in a more elegant way? I mean:
[tex]2\cdot 3\cdot 5\cdot 6\cdot \cdots \cdot \left( 3n -1 \right) \left( 3n \right) = \left[ 3\cdot 6\cdot 9\cdot \cdots \cdot \left( 3n \right) \right] \left[ 2\cdot 5\cdot 8\cdot \cdots \cdot \left( 3n-1 \right) \right] = n!3^n \times ( ? )[/tex]
and
[tex]3\cdot 4\cdot 6\cdot 7\cdot \cdots \cdot \left( 3n \right) \left( 3n +1 \right) = \left[ 3\cdot 6\cdot 9\cdot \cdots \cdot \left( 3n \right) \right] \left[ 4\cdot 7\cdot 10\cdot \cdots \cdot \left( 3n+1 \right) \right] = n!3^n \times ( ? )[/tex]
where [tex]( ? )[/tex] represents the other factor which I haven't been able to figure out so far.
Thank you
Problem
My Solution
If
and
Then
and so we have:
[tex]c_0[/tex]
[tex]c_1[/tex]
[tex]c_2[/tex]
[tex]\vdots[/tex]
and
Therefore
Questions
and
