Power distribution and heaters.
  • Context: Undergrad
  • Thread starter Thread starter siddharth5129
    Distribution Power
The discussion clarifies how power distribution systems manage increased loads, specifically when connecting a room heater. It establishes that a room heater's resistance is optimized to produce the desired power output, contrary to the assumption that it would be less power-intensive. When connected in parallel with other appliances, the total resistance decreases, resulting in an increase in total current supplied by the power distribution system. This mechanism ensures that the heater receives the appropriate power output as needed.
  • Understanding of Ohm's Law (V = IR)
  • Knowledge of power calculations (P = IV and P = I²R)
  • Familiarity with series and parallel circuit configurations
  • Basic principles of electrical resistance and conductance
  • Study the principles of electrical circuits, focusing on series and parallel configurations.
  • Learn about power distribution systems and how they manage load variations.
  • Explore the mathematical relationships in electrical power calculations.
  • Investigate the characteristics of different household appliances and their power consumption profiles.
Electrical engineers, students in electrical engineering, and anyone interested in understanding power distribution and appliance load management.
siddharth5129
This has to do with a fundamental doubt I have always had about power distribution. Say you hook up a room heater to your power supply. How exactly does the power distribution detect an increased 'load' and accordingly allot more power to your room. The way I understand it, the generating substation sends you electrical power at a fixed voltage (say 220V ). So 'loading' the power supply with the high resistance coil of a room heater should cause a reduced current to flow (according to V = IR ), and accordingly, a much smaller power output (according to P = i(squared)R ). So heaters should be the least power intensive of all household appliances, but obviously they are not, so what am I missing?
Science news on Phys.org
a) The resisance of a room heater is neither high nor low, it is if fact just right to produce the desired power output according to P=IV=I2R=V2/R.
b) You connect the heater in parallel with all the other loads you have. So the current through the heater is in addition to whatever current is flowing through other appliances you have. When you connect things in parallel, their combined resistance is calculated as 1/R= 1/Ra+1/Rb, that is you add conductances (reciprocals of resistance). See http://en.wikipedia.org/wiki/Series_and_parallel_circuits Note that R is always less than either Ra or Rb. So when you plug the heater in, total resistance as seen by the power supply decreases and the total current increases. If you go through the math you'll see it increases by just the right amount to produce the right amount of power in the heater.
  • · Replies 87 ·
  • · Replies 17 ·
