Thermal expansion of an interference fit
The discussion focuses on calculating the thermal expansion effects on an interference fit between a bearing made of High Lead Tin Bronze Alloy and a housing made of Grey Cast Iron. The bearing has an inner diameter of 15.92mm ± 0.005 and a thermal expansion coefficient of 18.5x10-6 1/°C, while the housing has a hole diameter of 15.88mm ± 0.005 and a thermal expansion coefficient of 11.7x10-6 1/°C. The user seeks to determine the housing's inner diameter at a temperature increase of 280°C, acknowledging the complexity of the geometry involved. The discussion also references the relationship between Young's modulus and diameter changes in interference fits.
  • Understanding of thermal expansion coefficients
  • Familiarity with interference fits in mechanical engineering
  • Knowledge of Young's modulus and its application in material science
  • Basic proficiency in using linear thermal expansion equations
  • Research the linear thermal expansion equation and its application to complex geometries
  • Explore the NSK catalog for detailed specifications on bearing fits
  • Study the effects of temperature on material properties, particularly for High Lead Tin Bronze Alloy and Grey Cast Iron
  • Investigate advanced methods for calculating thermal expansion in interference fits
Mechanical engineers, materials scientists, and anyone involved in the design and analysis of interference fits and thermal expansion in mechanical systems.
pardoeje
I have a bearing that is fixed into its housing by means of an interference fit (to test the effects of having a bearing that has become stuck due to build up of contaminants). I am using a bearing of ID 15.92mm ± 0.005 made of High lead Tin Bronze Alloy with a thermal coefficient of expansion equal to 18.5x10-6 1/°C within a housing with a hole of 15.88mm ± 0.005 made of Grey Cast Iron with a thermal coefficient of expansion equal to 11.7x10-6 1/°C. How do I calculate what the inside diameter of the housing will be when the part is running (delatT = 280°C). I have tried using the linear thermal expansion equation but due to the complex geometry of the housing I'm not really sure what OD to use for this method?
Any help would be greatly appreciated.
Science news on Phys.org
Usually with interface fits the change in the diameters is proportional to the module young of the materials. (so if you have 0.01 mm interface fit and both materials have the same module young then one diameter is now D1+0.005mm and the other diameter is D2-0.005mm).
You can also try NSK catalog - pages A82-A95.
  • · Replies 16 ·
10K
10K
9K
