Derivative of |sinx|: Solving Homework Problem
  • Thread starter Thread starter PirateFan308
    Derivative
The discussion revolves around computing the derivative of the function |sin(x)|, focusing on its differentiability and the application of the chain rule in calculus.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the piecewise nature of the absolute value function and its implications for differentiability. There are attempts to apply the chain rule, with some questioning the correct approach to handling the absolute value in the context of the sine function.
Several hints and clarifications have been provided regarding the piecewise definition of |sin(x)| and its derivative. Participants are actively engaging with the problem, examining different interpretations of the function's behavior based on the sign of sin(x).
There is an emphasis on the non-differentiability of the function at certain points, particularly where sin(x) changes sign. Participants are also considering the implications of using the sign function and alternative representations of the absolute value.
PirateFan308
Compute the derivatives of the following (where they are differentiable):
h) |sinx|
Chain rule: (f°g)'(c) = f'(g(c))(g'(c))
Let f=|x| and g=sin x
(f°g)'(c) = f'(g(x))g'(c) = f'(sin x)(cos x)
But I don't know what (|x|)' is. It's +1 when x>0 and -1 when x<0 and it's not differentiable at 0, but then there is no x to plug g into, and looking at the graph, I don't think this would be right. Thanks!
Hint:
[tex] \vert x \vert \equiv \left\lbrace\begin{array}{rl}<br /> x &, \ x \ge 0 \\<br /> <br /> -x &, \ x < 0<br /> \end{array}\right.[/tex]
Therefore:
[tex] \frac{d}{d x} \vert x \vert = \left\lbrace \begin{array}{rl}<br /> 1 &, \ x > 0 \\<br /> <br /> -1 &, \ x < 0<br /> \end{array}\right. \equiv \mathrm{sgn}(x)[/tex]
The derivative does not exist at [itex]x = 0[/itex].
Then, use the chain rule.
express the function piecewise to remove the absolute value sign.
eg |x| = {x: x>0 and -x: x<0 and 0: x=0}
[edit]Dickfore beat me to it
Dickfore said:
Hint:
[tex] Therefore:<br /> [tex] \frac{d}{d x} \vert x \vert = \left\lbrace \begin{array}{rl}<br /> 1 &, \ x > 0 \\<br /> <br /> -1 &, \ x < 0<br /> \end{array}\right. \equiv \mathrm{sgn}(x)[/tex]<br /> The derivative does not exist at [itex]x = 0[/itex].<br /> <br /> Then, use the chain rule.[/tex]
[tex] <br /> So if x>0, [itex](f°g)' = f'(g(x))g'(x) = (1)(cos x) = cos x[/itex]<br /> <br /> If x<0, [itex](f°g)' = f'(g(x))g'(x) = (-1)(cos x) = -cos x[/itex]<br /> <br /> Thanks for the hint![/tex]
What you have is not correct. sin(x) may be negative when x > 0 .
Your function is:
[itex]\vert \sin(x) \vert \equiv \left\lbrace\begin{array}{rl} <br /> \sin(x) &\text{if } \ \sin(x) \ge 0 \\ <br /> <br /> -\sin(x) &\text{if } \ \sin(x) < 0 <br /> \end{array}\right.[/itex]
So, what matters is the sign of sin(x), not the sign of x itself.
You can use the "sign" function sign(a)=a/|a| (http://mathworld.wolfram.com/Sign.html) to express the derivative of |sinx|.
It is also possible to use the identity
[itex]|a|=\sqrt{a^2}[/itex]
and determine the derivative of [itex]\sqrt{sin^2(x)}[/itex].
ehild
Thanks!
