New Reply
Help With Kinematics!
Share Thread Thread Tools
Jan17-12, 01:47 PM   #1
Two train cars are on a straight, horizontal track. One car starts at rest and is put in motion with a constant acceleration of 2.1 m/s2. This car moves toward a second car that is 25 m away and moving at a constant speed of 3.6 m/s.
(a) Where will the cars collide?
(b) How long will it take for the cars to collide?
2. Relevant equations
x= x0 + V0*t
x= 1/2(a)*t^2 + V0*t + x0
3. The attempt at a solution
This is a practice problem from WebAssign for our Physics course. My friend and I could not figure out how to solve this problem but we know the answer for both the parts which doesn't help since we don't know how to do the problem. If someone could help! Thanks!
a) 49.8 m
b) 6.89 s
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jan17-12, 02:39 PM   #2
Recognitions:
Homework Helper Homework Help
You should make some attempt at the problem.
When you get stuck in kinematics, it often helps to draw the v-t graphs for each object.
You need to find the time that the areas under the graphs is the same.... but you have to set them up right.
List what you know for each train:
x0, v0, a.
What is the equation that tells you the position of the constant-speed train?
What is the equation that tells you the position of the constant acceleration train?
(you've actually written them down - you just have to write in the numbers you know.)
New Reply
Tags
kinematics, motion, physics 101
Thread Tools
Similar Threads for: Help With Kinematics!
Thread Forum Replies
Physics - Kinematics/Rotational Kinematics Classical Physics 1
kinematics Introductory Physics Homework 2
Kinematics - which equation to use in kinematics problems? Introductory Physics Homework 14
possible for a body to have zero velocity and non-zero acceleration General Physics 4
Kinematics Introductory Physics Homework 1
