Calculating Forces in Electrostatic Fields w/ q & 4q
The problem involves calculating the forces acting on two fixed charges, 'q' and '4q', separated by a distance of 5 cm. The context is within electrostatics, specifically focusing on the interactions between point charges and the electric field they create.
  • Participants discuss the use of the electric field equation E = (k*q)/r^2 and the force equation F = qE. There is uncertainty regarding the values of the charges and how to express the final answer, particularly whether to combine q and Q into Q².
Some participants have provided guidance on the equations to use and emphasized the importance of unit conversion. There is ongoing exploration of how to express the forces on each charge and the implications of using different charge values in the calculations.
Participants note the lack of specific numerical values for the charges and the need to clarify how to handle the variables in the final expressions. The requirement to calculate forces on both charges is also highlighted.
bansal321
Hello i have a problem that i need help with.
Two fixed charges 'q' and '4q' are positioned along an axis with a separation d=5cm
a) Calculate the forces acting on each charge
Attempt
- I understand that the the force eqn is F = qE
- I also understand that i need to work out the Electric field before i can calculate the force
- and the electric field eqn is E = (k*q)/r^2??
what i don't understand is what are the values for the charges? There is no specific value for them, but they are written as 'q' and '4q'
Can anyone please offer some clarity to this please.
Thank you
You haven't been given the value of q but it certainly matters - the higher the q, the stronger the forces. So you will have a "q" in your answers.
You can use E = (k*q)/r^2 and then F = QE or put it together and just use
F = k*q*Q/r².
Thank you for the response!
ok so i understand now to use F = k*q*Q/r^2
for the charge 'q' i have => (9*10^9)*q*Q/25 => (3.6*10^8)*q*Q
would that be the final answer? Can i multiply q*Q to get Q^2? or should i just leave it as that?
Careful, you must convert your cm to meters. You don't want the two different Q's to appear in the final answer. Just put in "q" for one charge and "4q" for the other. You'll end up with a number times q².
The question actually asks for TWO forces, so you should really say something about the force on the q and the force on the 4q and how they are different.
  • · Replies 22 ·
