Which Ions Interfere with CrO4 2- Quantitation?
  • Thread starter Thread starter SebPT
    Cell Ions
The discussion revolves around the electrochemical determination of chromate ions (CrO4 2-) using a specific electrochemical cell setup. Participants explore which ions might interfere with the quantitation of CrO4 2- when added to the analyte solution, focusing on the roles of various cations and anions in the electrochemical reactions involved.
  • One participant describes the electrochemical cell and the expected reactions, expressing uncertainty about where interference might occur.
  • Another participant requests the Nernst equation for the measuring electrode, indicating a need for a deeper understanding of the electrochemical principles involved.
  • A participant corrects the half-cell reaction and notes that the reference electrode does not affect the interference from ions in the other half-cell.
  • It is suggested that the concentration of Ag+ near the electrode is controlled by the solubility product constant (Ksp) of Ag2CrO4.
  • One participant proposes considering the Ksp values of interfering ions with Ag+ and CrO4 2-, concluding that nitrate ions will not interfere due to their high solubility.
  • They further argue that S2- and Br- ions may form solid products with Ag+, potentially interfering with the half-cell reaction.
  • Discussion includes the idea of comparing standard reduction potentials of cations to determine their likelihood of interfering with Ag+ reduction.
  • Another participant reiterates the expectation that S2-, Br-, and Pb2+ ions will interfere with the quantitation of CrO4 2-.
Participants express a general agreement that S2-, Br-, and Pb2+ ions are likely to interfere with CrO4 2- quantitation, although the discussion contains varying levels of certainty and detail regarding the mechanisms of interference.
Participants discuss the Ksp values and standard reduction potentials without reaching a consensus on the exact nature of the interference, indicating that the discussion remains open to further exploration and clarification.
SebPT
The electrochemical cell:
SCE // CrO4 2- (x M) / Ag2CrO4 (s) / Ag (s)
is used for the determination of CrO4 2- . The standard reduction potential for the reaction:
Ag2CrO4 (s) + e = 2 Ag + CrO42-
is +0.446 V vs. NHE.
(b) Which of the following ions would be expected to interfere with CrO4 2- quantitation if added to the analyte solution:
NO3 - , Br - , S 2- , K + , Pb 2+
3. To solve this I guess I need to understand how the half cell is working. So I think the electrons coming from the salt bridge react with Ag2CrO4 (s) at the surface of the Ag electrode to produce a deposit of Ag on the metal and CrO42- which stays in solution. However I am not sure where the interference will take place. I am not sure if adding K and Pb cations will just take in electrons and reduce current or if some of the anions interfere at the electrode surface. Any help would be greatly appreciated!
Can you write Nernst equation for the measuring electrode?
S.C.E: 1/2Hg2Cl2 (s) + e-⇌Hg(l)+Cl-
Emeas=0.242V-0.05916*log[Cl-]
Note: the half cell rxn in the original post should be
Ag2CrO4 (s) + 2e- = 2 Ag(s) + CrO4 2- (aq)
I don't see how the reference electrode matters in this case, since the interfering ions are in the other half cell.
You are right, reference doesn't matter.
Hint: note that while you wrote reaction as the one between silver chromate and metallic silver, it is in fact Ag+ that gets reduced, just its concentration near the electrode is controlled by the Ksp of Ag2CrO4.
So, should I consider the Ksp values of the interfering ions with Ag+ and CrO42-
Then the nitrate ion won't interfere since it is highly soluble and will stay in solution. However, the Ksp of S2- and Br- with Ag+ is less than the Ksp of the silver chromate reaction. Does this mean that these ions will mostly form a solid product when interacting with Ag+ effectively interfering with the half-cell reaction?
When considering the cations, could I look at their standard reduction potentials and compare them to Ag+? I see that they are both lower and therefore, the reduction of Ag+ will be favoured, but lead chromate Ksp is also low, and will precipitate some CrO42- out of solution.
So the ions that interfere will be S2-, Br- and Pb2+?
That's what I would expect.
Sorry, no time for more detailed discussion, and I won't be able to read the forum for a week.
10K
9K
