Aspirin Questions: Seeking Guru Input
  • Thread starter Thread starter etc
Aspirin, a weak acid, is primarily in its un-ionized form when dissolved in stomach acid with a pH of approximately 1.5. Due to the high acidity, the majority of aspirin remains molecular rather than ionized. When un-ionized aspirin penetrates the stomach lining into less acidic regions, it can cause irritation. This phenomenon can be explained using Le Chatelier's principle, where a shift in equilibrium occurs in response to changes in pH, leading to increased H+ concentration and subsequent irritation.
  • Understanding of weak acids and their ionization behavior
  • Knowledge of pH scale and its implications on chemical equilibrium
  • Familiarity with Le Chatelier's principle
  • Basic concepts of molecular penetration through biological membranes
  • Research the ionization of weak acids in different pH environments
  • Study Le Chatelier's principle in the context of acid-base reactions
  • Explore the pharmacokinetics of aspirin and its effects on the gastrointestinal tract
  • Investigate methods to mitigate aspirin-induced gastric irritation
Students studying chemistry, pharmacology, or medicine, as well as healthcare professionals interested in the effects of aspirin on the human body.
etc
these questions were given to us to think 'bout for homework. I thought about the answers but I'm thinking i may be a bit wrong for some? i don't know .. if someone has an extra 2 minutes i'd appreciate their guru imput.
a)
stomach acid has a pH of about 1.5. Given the acidity of the stomach acid, would Aspirin dissolved in stomach acid be mostly in its ionized or un-ionized form?
For this I figured that aspirin is a weak acid and therefore doesn't fully ionize, in fact i think it's mostly in its molecular form. so, it must be in it's un-ionized form most, right? what i don't get about this is how they ask you to take into account the stomach's acidity ... ? anyone?
b) Un-ionized aspirin molecules can readily penetrate the stomach lining into a region of less acidity, this is where the stomach irritation associated with aspirin occurs. use le chatalier to explain.
for this i assume that since the pH is higher, then the equilibrium shift of the reaction would shift to the right and more H+ will be made, which is of course acidic, and it makes the new regions acidic, and therefore it irritates.
thanks guys!
Chemistry news on Phys.org
I suspect it is an equilibrium thing. Low pH = big H+ concentration, which would push the equilibrium with regards to the aspirin molecules a certain way...
Exactamondo!
  • · Replies 19 ·
11K
  • · Replies 20 ·
166K
