Find the mass of this boat using torque
  • Thread starter Thread starter Format
    Boat Mass Torque
The mass of the boat on the trailer is determined to be 11 kg using torque calculations. Initially, the scale reads 48 kg, and after moving the boat's center of gravity 0.15 m back, the scale reads 37 kg. The difference in weight indicates the mass of the boat. The torque equations used are: initial torque = (48 kg)(6.0 m) and final torque = (37 kg)(6.15 m), leading to the conclusion that the mass of the boat is 11 kg.
  • Understanding of basic physics concepts, specifically torque
  • Familiarity with weight measurement and scales
  • Knowledge of distance measurement in physics
  • Ability to set up and solve equations
  • Study the principles of torque and its applications in physics
  • Learn how to calculate center of gravity in various scenarios
  • Explore the relationship between force, mass, and acceleration
  • Practice solving problems involving static equilibrium
Students in physics, engineers working with mechanical systems, and anyone interested in understanding the principles of torque and weight measurement.
Format
A Trailer carrying a boat is supported by a scale which initially reads 48-kg. The boat (and therefore its centre of gravity) is moved 0.15-m further back on the trailer. The scale now reads 37-kg. Find the mass of the boat.
Kinda looks like this:
_______\___boat___/__
______|_______________O_______________
|------6.0-m-----|
Well, I've been tryin this question for 30 mins and i can't seem to get the right answer. I know F(d) = F(d) (where 'd' is the distance from the pivote)
but i don't know how to solve for the mass. If any of you can figure out my diagram and know wut to do...please help lol :smile:
Edit: k forget the diagram its just confusing lol. Just remeber that the boat is on a trailer with one point on the scale and then 6 meters away is the wheel. So there are 2 pivots.
The answer is 11 kg.First, calculate the weight of the trailer and boat before the displacement: 48 kg. Then, calculate the weight of the trailer after the displacement: 37 kg. The difference between these two is 11 kg, which is the weight of the boat.
To find the mass of the boat using torque, we can use the equation: torque = force x distance. In this scenario, the force is the weight of the boat and the distance is the distance from the pivot (scale) to the center of gravity of the boat. We can set up two equations using this information:
Equation 1: initial torque = final torque
Initial torque = (48 kg)(6.0 m) = 288 kg*m
Final torque = (37 kg)(6.15 m) = 226.05 kg*m
Equation 2: torque = force x distance
(48 kg)(6.0 m) = force x (6.0 m - x)
Where x is the distance from the pivot to the center of gravity of the boat when it is moved 0.15 m back.
Solving for x, we get x = 5.85 m. This means that the center of gravity of the boat is 5.85 m away from the pivot (scale) when it is moved 0.15 m back.
Now, we can plug in this value for x into equation 2 to find the force (weight) of the boat:
(48 kg)(6.0 m) = force x (6.0 m - 5.85 m)
force = 48 kg
Therefore, the mass of the boat is 48 kg.
  • · Replies 21 ·
