What Are the Possible Loci When d (x, y) = max {|x|,|y|}?
The discussion revolves around the mathematical definition of a distance function, specifically d(x, y) = max {|x|, |y|}, and its implications for determining the locus of points in the coordinate plane where this distance equals a constant. Participants are exploring the geometric interpretation of this function and its relationship to various shapes.
  • Conceptual clarification, Problem interpretation
  • Participants are questioning the meaning of the notation used in the problem, particularly the terms "max" and "d(x,y)." There is an exploration of the implications of the distance function and how it differs from classical distance. Some participants attempt to visualize the problem by graphing the functions involved.
The discussion is ongoing, with participants providing insights and clarifications about the function's definition. Some guidance has been offered regarding how to approach the problem graphically, but there is no explicit consensus on the interpretation of the locus yet.
Participants are working under the constraints of understanding the mathematical symbols and definitions involved. There is a noted lack of background knowledge from some participants, which is affecting their ability to engage with the problem fully.
Saitama
If the distance of any point (x,y) from the origin is defined as
d (x, y) = max {|x|,|y|},
d (x, y) = a non zero constant, then the locus is
(a) a circle
(b) a straight line
(c) a square
(d) a triangle
I don't understand what does the question mean by "d (x, y) = max {|x|,|y|}"?
Can somebody tell what does the notation mean? I never encountered problems like these.
Any help is much appreciated.
Thanks! :smile:
what do you understand of the various symbols used?
What does "|x|" mean, for example
If you have no idea what the symbols mean, one has to wonder what you are doing working on the problem with no background, but if you do understand them, then say what they are and see where that leads.
I know what does |x| mean. My question is what does this "max" and "d(x,y)" mean?
(x,y) are the co-ordinates of a point but i don't understand what this "d(x,y)" mean.
Thanks for the reply! :smile:
d(x,y) is just a function, it is not the same as the classical distance. It is defined as max(|x|,|y|), so d=|x| when |x|>|y| and d=|y| when |y|>|x|. Find the locus where d(x,y)= constant. Draw a picture of the coordinate system and find the regions where |y|>|x| and |x|>|y|. Draw the lines d=const. You will see the solution at once.
ehild
ehild
I drew the graph of the both |x| and |y| on the same graph and found that the graphs of both |x| and |y| coincides with each other.
Is the coinciding line is my answer?
NO. Show your drawing, please. You need to find those points in that domain of the x,y plane where |y|>|x| for which d(x,y)= |y| =const, for example d(x,y) = |y|=5. And also find those points (x,y), |x|>|y|, for which d(x,y)=|x|=5
ehild
ehild
My graph is similar to this:- http://www.wolframalpha.com/input/?i=|y|=x,y=|x|
The plot is a good start to show the domains, but complete it for x<0, y<0. Then draw the line(s) |y|=5 in the range |x|<|y|.ehild
ehild
Here's the graph which i drew (Not to scale):-
|y|=5, that mean y=5 or y=-5, i draw both of them but i still don't understand what you mean by |x|<|y|?
Sorry if this is annoying for you.
The lines y=5 and y=-5 do not extend to infinity. d(x,y)=max(|x|,|y|)=5. It is equal to |y| while |y|>|x|, in the yellow area of the x,y plane. In the blue area, where |x|>|y|, d(x,y)=5=|x|. Draw it.
ehild
Hi Pranav! :smile:
Perhaps you could consider a few points in the plane.
Like (x=1, y=5), (-4,5), (-6,5), (1,1), (-5,4), (-5,-4), (-3,-5).
Can you say what max(|x|,|y|) is in each case?
