Need help on a rotational dynamics problem for tomorow please
The discussion focuses on solving a rotational dynamics problem involving an inverted "A" suspended by two vertical ropes. Each leg of the "A" has a length of 2L and a weight of 120.0N, with the horizontal crossbar having negligible weight. The angle at the top of the "A" is 60 degrees. To find the force that the crossbar applies to each leg, one must draw a free body diagram, apply the principles of torque and equilibrium, and resolve the moments about the point of suspension.
  • Understanding of rotational dynamics principles
  • Knowledge of torque and equilibrium concepts
  • Ability to draw and interpret free body diagrams
  • Familiarity with trigonometric functions related to angles
  • Study the principles of torque in rotational dynamics
  • Learn how to construct and analyze free body diagrams
  • Explore equilibrium conditions for static structures
  • Investigate trigonometric applications in physics problems
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators seeking to enhance their teaching methods in these topics.
Crazedkid
hi i need help understanding what to do with the information that was given in the problem if u could point mein the right direction i would greatly appreciate it. thank you
An invered "A" is suspended from the ceiling by 2 vertical ropes. Each leg of the "A" has a length of 2L and a weight of 120.0N. The horizontal crossbar has a negligable weight. Find the force that the crossbar applies to each leg.
Known:
W=120.0N per leg
l of legs= 2L
angle at top of "A" = 60Degrees
l of crossbar=L
You have to figure out where the cross bar is located along the long legs.
So draw a diagram of the inverted A. The angle at the bottom is 60°. Placing the crossbrace (length L) inside the A, it must make 60° with each leg then (and each side of the triangle formed is L. So the crossbrace attaches to the long leg at L (midway).
But at the ends of the A, there is a tensile force (120 N) acting vertically on the leg. You then need to resolve the moment about the point of the A. This moment is acting on the crossbrace.
Ratio of moment arms.
Hi there,
It seems like you are struggling with a rotational dynamics problem involving an inverted "A" suspended from the ceiling. First, it's important to understand the information that was given in the problem. You are given the weight and length of each leg of the "A", the angle at the top of the "A", and the length of the horizontal crossbar.
To solve this problem, you will need to use the principles of torque and equilibrium. The first step would be to draw a free body diagram to visualize the forces acting on the "A". Remember that for rotational motion, the net torque must be equal to zero in order for the object to be in equilibrium.
Next, you can use the equation torque = force x perpendicular distance to find the torque exerted by the weight of each leg on the "A". Since the angle at the top of the "A" is given, you can use trigonometry to find the perpendicular distance from each leg to the point of suspension.
Once you have the torque exerted by each leg, you can set them equal to each other and solve for the force applied by the crossbar on each leg. Remember to take into account the direction of the force, as it will be different for each leg.
I hope this helps point you in the right direction. Good luck with your problem and let me know if you have any further questions.
  • · Replies 19 ·
  • · Replies 30 ·
  • · Replies 26 ·
