A fast image recognition algorithm for box?
The discussion focuses on identifying the four corners of a box in a noisy black and white image using image processing techniques. The recommended approach involves applying a 2D low pass filter, specifically a Gaussian filter, to reduce noise before detecting edges. The process includes convolving the image with a Gaussian matrix or utilizing the Fast Fourier Transform (FFT) to enhance the image quality. Following the filtering, calculating the gradient in both the x and y axes helps pinpoint where the box appears in the image.
  • Understanding of 2D low pass filtering techniques
  • Familiarity with Gaussian blur and its application
  • Knowledge of Fast Fourier Transform (FFT) in image processing
  • Basic concepts of image gradients and edge detection
  • Research Gaussian blur implementation in Python using OpenCV
  • Learn about Fast Fourier Transform (FFT) for image processing
  • Explore edge detection techniques using gradients in images
  • Investigate other noise reduction algorithms suitable for image preprocessing
Image processing engineers, computer vision researchers, and developers working on applications requiring robust box detection in noisy environments.
nhmllr
If you have an image (just black and white) with a box SOMEWHERE in the image, but there's also some noise in the image, is there a good way to find four corners?
I'm sure someone has herd of an algorithm for this, it would just be good if I had a direction to go in.
Technology news on Phys.org
I would advise to use a 2D low pass filter first to get rid of the noise as much as possible. In other means convolve the image with a gaussian matrix. Or in other saying take fft of the image and multiply with the fft of the gaussian matrix. And then take the inverse of the solution. Dimensions of the gaussian matrix will determine the cut of spatial frequency:
http://en.wikipedia.org/wiki/Gaussian_blur#Sample_Gaussian_matrix
There should be a builtin gaussian filter in the environment you are working. Other than that if I were you I would take a gradient of the filtered image both x and y-axis to see in which pixels the box started to appear.
  • · Replies 30 ·
  • · Replies 43 ·
12K
