Test of two distributions/functions
  • Context: Graduate
  • Thread starter Thread starter phonic
    Test
The discussion centers on testing the statistical significance between two functions, f1(x,y) and f2(x,y), defined on a table with constraints 1 ≤ f1(x,y) ≤ 1 and 1 ≤ f2(x,y) ≤ 1. The initial suggestion was to use a chi-square test after adding a constant n > 1 to interpret the functions as frequencies. However, it was clarified that statistical significance requires a defined probabilistic process for the functions, and without this, the appropriateness of the chi-square test is questionable.
  • Understanding of statistical significance and hypothesis testing
  • Familiarity with chi-square tests and their applications
  • Knowledge of probabilistic processes and random variables
  • Basic concepts of functions and their definitions in statistical contexts
  • Research the assumptions required for chi-square tests in statistical analysis
  • Learn about different probabilistic processes and their implications for hypothesis testing
  • Explore alternative statistical tests suitable for comparing functions
  • Study the concept of uniform random variables and their applications in statistical modeling
Statisticians, data analysts, and researchers involved in hypothesis testing and statistical modeling who need to understand the nuances of comparing functions and the appropriate tests to apply.
phonic
Dear All,
I have two functions that are defined on a table, i.e. [itex]f1(x,y), f2(x,y)[/itex], where x and y are bin indices, and [itex]1\leq f1(x,y) \leq 1[/itex], [itex]1\leq f2(x,y) \leq 1[/itex].
I would like to perform some test to show whether [itex]f1(x,y)[/itex] and [itex]f2(x,y)[/itex] are significantly different. Is there some way to do this? I thought of using chi square test for [itex]f1(x,y)+n[/itex] and [itex]f2(x,y)+n[/itex], where n>1 is a constant added to make [itex]f1(x,y)[/itex] and [itex]f2(x,y)[/itex] interpretable as frequencies.
Thanks a lot!
Statistical signficance is not a meaningful concept unless you are dealing with a phenomena that involves probability. To do the usual type of "hypothesis testing" , you must assume the two functions are generated by the same probabalistic process. Until you state exactly what that process is, it isn't possible to say what sort of statistical test is appropriate.
For example if we assume each table is generated by one realization of the uniform [0,1] random variable u according to the formula [itex]f(i,j) = (-0.5)(i) - (0.5)(j) + u[/itex] then it wouldn't make sense to do a chi square test.
  • · Replies 23 ·
  • · Replies 0 ·
