What is the Solution to Simplifying Trig Expressions?
  • Thread starter Thread starter bobsmith76
    Cosine Sine
The discussion revolves around simplifying trigonometric expressions, with participants examining steps from a textbook that appear unclear. The subject area is trigonometry, particularly focusing on identities and algebraic manipulation.
  • Participants express confusion regarding the transition between steps in a solution, particularly questioning the cancellation of terms. There is mention of the fundamental trigonometric identity involving sine and cosine, and some participants suggest reviewing algebraic principles related to fractions and cancellation.
Guidance has been offered regarding the importance of trigonometric identities and algebraic manipulation. Multiple interpretations of the problem are being explored, with participants reflecting on their understanding of cancellation and simplification.
Some participants indicate a lack of familiarity with trigonometric identities and basic algebra, which may be affecting their ability to simplify expressions correctly. There is an emphasis on the need to clarify these foundational concepts.
bobsmith76
I don't see how the textbook gets from step 1 to step 2. If anything, the cosines cancel and the answer should be (sine^2)x
One of the best known trigonometric identities is : [itex]\cos^2 x + \sin^2 x = 1[/itex]. To see this, just draw a right angle triangle, with one of the acute angles marked x and the hypotenuse measuring 1 unit. One side (opposite angle x) measures sin x and the other side (adjacent to angle x) measures cos x. You can immediately see the identity with Pythagoras' Theorem.
Remember that [itex]\frac{a^2 + b^2}{a^2} \neq b^2[/itex]. Cancellation doesn't work that way. It is true, however that [itex]\frac{a^2b^2}{a^2} = b^2[/itex] (when a is nonzero).
thanks, trig identities, I forgot about them
(a-b)/a
You can't cancel a out unless you take the common factor out of parenthesis:
[a(1-b/a)]/a
Now you can cancel a's out and you will be left with 1-b/a
Another example:
(a-ab)/a= [a(1-b)]/a=1-b
To cancel you always have to get the common factor out of parenthesis.
You pretty much can't simplify trig expressions without having a few identities in mind, so I would advise you to spend some time reviewing them.
I would also advise reviewing basic algebra, particularly fractions and rational expressions, since you seem to have forgotten those concepts, as well. You should wipe the word "cancel" from your mind, since students who are uncertain about what this actually means are prone to making mistakes.
  • · Replies 33 ·
