Equation of temperature increase by shock wave
The discussion revolves around the equations and phenomena related to temperature increase caused by shock waves in ideal gases, particularly in the context of a piston-induced shock wave. Participants explore the mechanics of shock wave propagation, the influence of piston speed, and the complexities introduced by turbulence.
  • One participant inquires about the specific equation for temperature increase when an ideal gas is affected by a planar shock wave.
  • Another participant questions why a shock wave can propagate faster than the piston that generates it, seeking to understand the factors that determine shock speed.
  • A participant explains that the shock wave is a discontinuity in pressure and that the piston itself does not exceed the speed of sound, but the air can reach those velocities.
  • There is a request for equations related to shock speed and its dependence on initial piston speed.
  • One participant suggests looking up normal shock relations for comprehensive equations and recommends studying compressible flow for deeper understanding.
  • Another participant describes the complexity of the phenomenon due to the turbulent airflow caused by the piston’s motion, noting that pressure discontinuities arise from changes in airflow direction.
  • Participants discuss the validity of normal and oblique shock equations in laminar versus turbulent flows, with some arguing that turbulence has minimal effect on shock formation.
  • There is a debate regarding the role of turbulence in predicting shock wave behavior, with some asserting that turbulence is inherently accounted for in the Navier-Stokes equations.
  • One participant mentions that the speed of sound increases behind a compression wave, which could lead to shock formation if the piston compresses the air sufficiently quickly.
Participants express multiple competing views regarding the influence of turbulence on shock wave behavior and the conditions under which shock waves form. The discussion remains unresolved, with no consensus on the specifics of shock wave dynamics in relation to piston motion.
Participants note the complexity of the scenario, including the dependence on flow conditions, piston speed, and geometry. There are references to the need for solving the Navier-Stokes equations under compressible flow conditions, indicating that assumptions about flow characteristics may affect the outcomes.
ada_ada_2002
【HELP】Equation of temperature increase by shock wave
Hi there!
What is the equation of the temperature increase when the ideal gas swept by a planar shock wave (Mach number, M)?
Thank you!
Science news on Phys.org
Another question:
If the shock wave is triggered by a piston, why it can propagate at a speed larger than that of the piston? what determine the speed of a shock?
I don't have my book handy to tell you the equation, but as for the second question:
The shock wave is a discontinuity in air pressure. Keep in mind that, while the shock wave is caused by your piston, the actual cause is that the air around it is moving in a certain way.
The propagation velocities are in the order of magnitude of the speed of sound. Your piston is probably moving quite slower than that. You get a shock wave because there is a discontinuity in pressure at some point around the piston.
This is the tricky part:
The piston itself is not moving faster than sound, the air at some point(s) reaches those velocities.
Thank you meldraft!
So, how to calculate the speed of a shock? is there any equations? I just what to know what exactly influence the shock speed.
BTW, I have found the temperature equation
You would do well to look up normal shock relations. They will have all the relations you are asking for and more. If you intend to do this a lot, it may be a good idea to pick up a book on compressible flow and learn where it all comes from.
Not intended to do this subject a lot, just curious.
Anyway, cannot find relations between initial piston speed, and the consequent shock speed. Just know that shock propagate ahead of the piston. By how much exactly?
The phenomenon you are asking is very complex because, in contrast to an aircraft, the piston is moving back an forth, which means that the air flow is fully turbulent.
That being said, I imagine that the discontinuity in pressure would be caused by sudden changes in the direction of the airflow, caused by the alternating pressure between upstroke and downstroke.
For an aircraft, these are the equations:
http://www.grc.nasa.gov/WWW/k-12/airplane/normal.html
http://www.grc.nasa.gov/WWW/k-12/airplane/oblique.html
For a piston, unless you can find something in a book that I am not aware of, you would have to solve the Navier-Stokes with turbulence to see when the shock waves are formed.
A rough approximation is to consider a plane that is moving in one direction in a container where the air is moving in the other direction. If you solve the equations, you will get when the Mach number becomes greater than 1, as a function of the displacement of the piston. This value will depend on the relative velocity between the air and the piston, as well as the geometry you assume.
Your answer is quite clear! Thank you SO MUCH, Meldraft!
Turbulence has absolutely no effect in this case. The only time turbulence would have an effect is in the case of a boundary layer, and then only because you change the shape of the boundary layer. The normal and oblique shock equations are equally valid for laminar and turbulent flows except near boundaries since the normal and oblique shock relations assume inviscid flow. Then again, that means that they aren't really valid near boundaries for laminar flow either.
In general, in compressible fluid mechanics like this, the inviscid approximation is very good because (a) the flows generally involve very high Reynolds numbers, so the viscous terms are small in comparison to the rest of the terms and (b) the boundary layer is typically very thin until you start stepping into the hypersonic regime, where it can actually get very thick.
Additionally, saying things like "solve the Navier-Stokes equations with turbulence" really has no meaning. Turbulence is already built into the Navier-Stokes equations. It is fully described by them. The only difference in the Navier-Stokes equations in this case and what are traditionally used is that since this is a compressible flow, one cannot drop the bulk viscosity term as is typical. This still has nothing to do with turbulence.
You are saying that you can predict where the shock wave will be shaped and how it will look like, as a time dependent phenomenon, in a small closed container, and, possibly, fuel coming in, by ignoring turbulence. If this sounds right to you, I'm not one to argue :smile: I will just point out that the equations are still valid, but your field does not look like you would expect for laminar flow.
The person that manages to solve that will get a Nobel prize :biggrin: That is why we have turbulence models, or choose to neglect it.
Without knowing more about his scenario, I can't say for sure, but there are plenty of piston systems that create shocks in laminar flow, and plenty that create them in turbulent flow. It just depends on where in the flow you are looking and a host of other factors. A piston in an open pipe is a pretty canonical problem, and you can look at the pressure created by the piston to determine the shock velocity and location as a function of time.
Consider that the piston compresses the air directly in front of it, but this compression travels at the speed of sound, so it moves faster than the piston. However, after each infinitesimal compression, the speed of sound actually gets a little bit faster behind that wave, so if the piston is moving fast enough that it compresses the air quickly enough, each successive compression will slowly catch up to the previous one until eventually they can coalesce into a shock.
That isn't really true. People solve them directly all the time. It is called direct numerical simulation, or DNS. The real problem is that due to the incredibly large range of length scaled involved in turbulence, you need a large, incredibly fine mesh in order to do that, so the only real way to get a converged solution is to put the problem on a supercomputer and let it run. Right now, DNS can do a pretty good job of simulating turbulent flows, but only at low Reynolds number and it definitely can't simulate the transition from laminar to turbulent flow given what we know now, so it definitely has its limitations.
  • · Replies 18 ·
  • · Replies 0 ·
  • · Replies 22 ·
