New Reply
Modulus problem
Share Thread Thread Tools
Jan25-12, 07:57 AM   #1
Modulus problem
I would like to know how to prove that the number n^3 + 2n is divisible by 3 for all integers n. I know that I am supposed to examine the possible remainders after division with 3. The possibilities are:
n= 0,1,2 (mod 3)
Could somebody please help me? How can the expression of n^3 + 2n possibly become a number composed by at least one factor 3?
Thank you by forehand,
dobedobedo
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jan25-12, 08:10 AM   #2
Do you understand the Induction Hypothesis?
Jan25-12, 08:39 AM   #3
No, I do not have much experience with modulus calculation and I haven't heard of that hypothesis. I do understand the basic theorems:
If:
α= β (mod C)
and
a = b (mod C)
Then
α*a = β*b (mod C)
and
α + a = β + b (mod C) [1]
I've made some tables showing the mod 3 values for numbers n^3 and 2n:
[2n] 0 2 4 6 8 10 12 14 16
[mod 3] 0 2 1 0 2 1 0 2 1
[n^3] 0 1^3 2^3 3^3 4^3 5^3 6^3 7^3 8^3
[mod 3] 0 1 2 0 1 2 0 1 2
According to [1], 2n + n^3 should be divisible by 3 (if you add the numbers of the rows corresponding to mod 3, you will get always 3 or 0, so the number is divisible by 3 SEE BELOW), if the patterns above don't stop repeating themselves.
[2n+n^3]
[mod 3] 0 3 3 0 3 3 0 3 3
The only problem I see, is that I am unable to prove that this pattern, of numbers congruent to 2n and n^3, repeats in all eternity, making the sum of [2n] and [n^3] equal to 3 or 0.
What is the induction hypothesis btw?
Jan25-12, 08:55 AM   #4
Modulus problem
I'd use the induction hypothesis to prove it.
Basically the induction hypothesis shows that if something works for n then it will work for n + 1, which then shows it will work for all values of n.
http://en.wikipedia.org/wiki/Mathematical_induction
That should explain it in more detail.
First of all you need a basis, to do this show that your hypothesis (that its divisible by 3 for all values of n) works for a small value of n - you can use either n = 0 or n = 1.
Then you substitute in n+1 for n in your first expression.
So in full your proof should look a bit like:
For any natural number n, n3 + 2n is divisible by 3.
Proof:
Basis: If n = 0, n3 + 2n = 03 + 2×0 = 0.
0 mod 3 = 0, therefore it is divisible by 3.
Induction: Assume that for an arbitrary natural number n, n3 + 2n is divisible by 3.
Induction Hypothesis: To prove this for n+1, first try to express ( n + 1 )3 + 2( n + 1 ) in terms of n3 + 2n and use the induction hypothesis.
( n + 1 )3 + 2( n + 1 ) = ( n3 + 3n2 + 3n + 1 ) + ( 2n + 2 )
= ( n3 + 2n ) + ( 3n2 + 3n + 3 )
= ( n3 + 2n ) + 3( n2 + n + 1 )
Therefore n3 + 2n is divisible by 3 by the induction hypothesis.
I'm not great with proofs so prehaps someone else could just check that.
Jan25-12, 09:31 AM   #5
I am a little confused. The term 3(n^3 + 1) is certainly divisible by 3 - but what about the other term (n^3 + 2n) ? Aren't we back at the same situation?
Jan25-12, 09:35 AM   #6
With the inductive hypothesis, we assumed that n3+2n was divisible by 3 for n, and now you're proving the same for n + 1.
It's like knocking down a line of dominoes, if we can prove that the first domino falls over (basis) and each domino knocks over the next (inductive step), then that means that all of the dominoes in the line get knocked down eventually.
You know that (n3+2n)+3(n2+n+1) is divisible by 3 because n3+2n is (because of the inductive hypothesis) and 3(n2+n+1) is (because it's 3 times an integer). So, their sum is as well.
Jan25-12, 09:56 AM   #7
Ok, thank you very much for your suggestion, but on the wikipedia article it says that induction works for positive integers. If I would like to extend my reasoning to include negative integers as well - what would be an effective way of proving that n^3 + 2n is divisible by 3 for all n?
Jan25-12, 10:53 AM   #8
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Well, go back to your orginal idea of looking at it "modulo 3".
All integers are equivalent to 0, 1, or 2. If n= 0, [itex]n^3+ 2n= 0^3+ 2(0)= 0[/itex]. If n= 1 [itex]n^3+ 2n= 1^3+ 2(1)[/itex] mod 3. if n= 2,. [itex]n^3+ 2n= 2^3+ 2(2)[/itex] modulo 3. What do those tell you?
Another, related, way- every integer, n, is equal to one of 3m, 3m+1, or 3m+ 2. Calculate [itex]n^3+ 3n[/itex] for each of those.
Jan25-12, 11:19 AM   #9
That helped, now I am very satisfied. :) Thank you very much, both of you.
New Reply
Tags
homework, modulus, problem
Thread Tools
Similar Threads for: Modulus problem
Thread Forum Replies
Spring Desing : How to Achive given shear modulus or modulus G and P(N) General Physics 0
Derive relationship between Young modulus and Shear modulus Introductory Physics Homework 0
young's modulus and bulk modulus of cooked pasta Classical Physics 4
Young modulus problem. Introductory Physics Homework 16
Modulus problem Introductory Physics Homework 7
