How to show integral identity involving gaussian over x
The integral identity involving the Gaussian function and the error function is established as follows: \[ \int d\vec{x} \frac{ e^{- x^2 }}{ \left| \vec{x}-\vec{y} \right| } = \frac{\pi^{3/2}\text{Erf}\left[ y \right]}{y} \] This identity is derived using spherical coordinates with the z-axis aligned along the vector \(\vec{y}\). The solution involves evaluating the integral over three-dimensional space, leading to two distinct integrals that can be referenced in integral tables or computed using Mathematica. The discussion highlights the importance of correctly handling the term \(\sqrt{(r-y)^2}\) based on the relationship between \(r\) and \(y\).
  • Understanding of integral calculus, specifically in three dimensions.
  • Familiarity with Gaussian functions and the error function (Erf).
  • Knowledge of spherical coordinates and their application in integrals.
  • Experience with computational tools like Mathematica for integral evaluation.
  • Study the properties and applications of the error function (Erf) in mathematical physics.
  • Learn how to convert Cartesian coordinates to spherical coordinates for integration.
  • Explore integral tables for common Gaussian integrals and their solutions.
  • Practice using Mathematica for solving complex integrals and verifying results.
Graduate students in physics, mathematicians, and researchers dealing with complex integrals in theoretical physics, particularly those studying plasma physics or related fields.
luke
So I have come across this integral identity in Krall's Principles of Plasma Physics (right after equ. 6.4.4 in the 1st edition) and I have not been able to show the identity is true. The reason that I would like to understand the integral is that I am trying to solve a similar problem to the one done in the book. I am hoping that understanding how solve the integral given below will help me with others.
The identity that Krall uses is:
[itex]\int d\vec{x} \frac{ e^{- x^2 }}{ \left| \vec{x}-\vec{y} \right| } = \frac{\pi^{3/2}\text{Erf}\left[ y \right]}{y}[/itex]
Where x,y denote the magnitude of the x,y vectors and Erf is the error function. The integral on x is over all 3D space.
I suppose in the end I want to know how to show the identity is true. It would also be helpful is someone has seen this or similar integrals in table of integrals. Resources that are related are welcomed. I would also just like some more ideas on how to attack it.
My best attempts were using:
spherical coordinates (with z-axis along y-direction)
differentiating under the integral with respect to magnitude if y
I'm in my 3rd year of grad. school in physics so hopefully you won't need to spell it all out for me to follow. Thanks!
I solved it (after some friends pointed out some simple mistakes I was making).
For the record, here is how I did it. I will use spherical coordinates with the z-axis aligned with [itex]\vec{y}[/itex]
[itex]\int d\vec{x} \frac{e^{-x^2}}{\left| \vec{x} - \vec{y}\right|} = \int_0^{2 \pi} d\theta \int_0^\pi d\phi \int_0^\infty dr \frac{r^2 \sin \phi e^{-r^2}}{\sqrt{r^2 + y^2 - 2 y r \cos \phi}}[/itex]
Now do the [itex]\theta,\phi[/itex] integrals
[itex]\int d\vec{x} \frac{e^{-x^2}}{\left| \vec{x} - \vec{y}\right|} = \int_0^\infty dr \frac{2\pi r}{y} e^{-r^2} \left( r + y - \sqrt{(r-y)^2} \right)[/itex]
The cute thing to notice (pointed out by my friend) is that we must treat [itex]\sqrt{(r-y)^2}[/itex] in parts for when [itex]r>y[/itex] and [itex]y>r[/itex]. Now we have two integrals:
[itex]\frac{4\pi}{y}\int_0^y dr r^2 e^{-r^2} + 4\pi \int_y^\infty dr r e^{-r^2}[/itex]
Then we can just look these integrals up in a table or use Mathematica. I hope this helps someone who gets stuck on this integral like me.
  • · Replies 19 ·
  • · Replies 20 ·
