What do you call this kind of attraction?
  • Context: High School
  • Thread starter Thread starter Buzzworks
    Attraction
The phenomenon described involves two pieces of dry glass material that, when pressed and rubbed together, create a strong attraction due to the removal of air between them, leading to a vacuum effect. This results in a friction force that prevents them from being easily separated, akin to the attraction of a neodymium magnet to iron. The action does not cause any physical damage to the glass surfaces. This discovery was made using glass prisms from binoculars, highlighting an interesting aspect of material interaction.
  • Understanding of basic physics principles, particularly pressure and vacuum.
  • Familiarity with material properties of glass.
  • Knowledge of friction and adhesion concepts.
  • Experience with experimental observation techniques.
  • Research the physics of adhesion and the role of air pressure in material interactions.
  • Explore the properties of different types of glass and their friction characteristics.
  • Investigate vacuum effects in material science.
  • Learn about practical applications of adhesion in engineering and design.
Physics enthusiasts, material scientists, and anyone interested in the principles of adhesion and friction in everyday materials.
Buzzworks
-You get two pieces of dry glass material with perfectly flat faces.
-You press and rub them together. Initially, they seem to glide smoothly against each other...
-...Eventually, after a few strokes, friction force gets very strong until the point you can't rub them at all.
-A this stage the two pieces of glass have become stuck to each other, strongly!
-They will remain stuck indefinitely until you force them apart. You can drop them on the carpet and still remain stuck, you get the idea that this is a very strong attraction, almost like a neo magnet to iron!
-The action does not cause any damage, no scratch, nothing.
-I suspect the action drives all the air out between the glass pieces and outside air pressure takes over??
-I discovered this by accident when I decide to amuse myself with two glass prisms from a pair of binoculars! Any ideas what causes this attraction?
11K
