Photons of different energy follow different geodesics?
The discussion revolves around the behavior of photons of different energies as they pass near massive bodies, specifically whether they follow the same geodesic paths or if their energy influences their trajectories in curved spacetime. The scope includes theoretical considerations from general relativity and the implications of energy on geodesic motion.
  • Some participants assert that photons of different energies follow the same light-like geodesic, suggesting that if this were not the case, a "gravitational rainbow effect" would be observable.
  • Others propose that in principle, photons of different energies do follow different paths, although the effect is minimal, with low-energy photons being larger and thus experiencing different gravitational influences.
  • A participant mentions that high-energy photons can distort the gravitational field, leading to a scenario where both the photon and the massive body orbit a common center of mass.
  • There is a discussion about the distinction between treating photons as point-like particles versus wave packets, which may affect the interpretation of their paths.
  • One participant references a result in general relativity indicating that anti-parallel beams of light attract each other, implying that energy can influence the path of light in certain configurations.
  • Another participant emphasizes that the null geodesic is generally independent of photon energy, noting that while photons are approximated to follow geodesics, this is not strictly accurate in all scenarios.
  • Further, a participant introduces the Papapetrou equations as a means to analyze the motion of photons beyond the null-geodesic approximation, suggesting potential energy-dependent effects.
Participants express differing views on whether photons of different energies follow the same geodesic paths, with some asserting they do and others suggesting that energy does have an effect, albeit small. The discussion remains unresolved with multiple competing perspectives on the topic.
Participants note that the approximation of photons following geodesics may not hold in all cases, particularly when considering the gravitational influence of the photons themselves or when accounting for their wave-like properties. The discussion highlights the complexities involved in accurately describing gravitational interactions involving light.
jnorman
a massive body like a star creates a warped spacetime in its vicinty. this warped geometry of space is reflected by the geodesics appropriate to its mass. a photon passing by this massive object is not, as per GR, "attracted" to the star via some "force", but rather simply follows what it sees to be a "straight" line, while in reality that "straight" line is actually curved due to the mass of the star warping the surrounding space. ie, the photon is not accelerated due to a change in its apparent direction, since it thinks it is traveling in a straight line - it "feels" no force acting upon it. (i hope that is all correct...)
if we start changing the energy of the passing photon, does this also change the geodesic which it follows past the star? ie, will a radio wavelength photon follow the same "straight" line as a gamma ray photon?
i assume that if we replace "photon" in the question with "massive body" and consider the path of a body of small mass, such as an asteroid, compared to the path of a larger mass body such as a planet sized object, they will follow different paths because the mass of each will both be affecting the overall geodesics of the system. (correct?)
since photons do not have "mass" do photons of different energy follow the same geodesic path, or does the energy of a photon also affect the overall warping of spacetime, such that different wavelngth photons follow different paths past the star?
thanks.
photons of different energy (emitted in the same rest frame with different frequency) follow the same (light-like) geodesic; otherwise you would see a "gravitational rainbow effect"
In principle, photons of different energies follow different paths, although it is a very small effect. For a very low energy photon, the size of it will be correspondingly large. Parts of it will be in different places and hence feel different attraction. In fact, part of it will even be on the opposite side of the attracting body.
On the other hand a very high energy photon will distort the gravitational field. In fact both the photon and the attracting body will orbit a common center of mass.
Bill, now you are not talking about photons as pointlike particles but about wave pakets.
Well, there is a result in GR that two anti-parallel beams of light attract, while parallel, they don't. Clearly, in the former case, the light path would depend on energy (and while both paths would be lightlike, neither would be a geodesic of the background geometry).
Now you include back-reaction.
I agree - as you said, it's no longer about geodesics in pure gravity
yes. I think you are asking about a [theoretical] test particle geodesic:
Here is how Wikiepdia explains it...
...True geodesic motion is an idealization where one assumes the existence of test particles. Although in many cases real matter and energy can be approximated as test particles, situations arise where their appreciable mass (or equivalent thereof) can affect the background gravitational field in which they reside.
This creates problems when performing an exact theoretical description of a gravitational system (for example, in accurately describing the motion of two stars in a binary star system). This leads one to consider the problem of determining to what extent any situation approximates true geodesic motion. In qualitative terms, the problem is solved: the smaller the gravitational field produced by an object compared to the gravitational field it lives in (for example, the Earth's field is tiny in comparison with the Sun's), the closer this object's motion will be geodesic.
http://en.wikipedia.org/wiki/Geodesic_(general_relativity)#Approximate_geodesic_motion
thanks.
A geodesic is essentially an one-body solution. First you take the start as if it is alone and obtain the spacetime distortion. Once you computed it (e.g. Schwarszchild) you place an object (test body) and assume that spacetime distortion is unchanged.
This is an excellent approximation when mass (energy) of test body is much smaller than mass of the source body.
Therefore, the geodesic does not depend of test body properties. Indeed light bending around sun depends only on Sun gravitational 'field'.
In a more complete model you would solve the two-body problem, and obtain the two-body equation of motion, which of course is not a geodesic.
Let's recap a bit:
The null geodesic is independent of the energy of the photon.
It's really only an approximation that photons follow geodesics - though it's a pretty good one. Sometimes elementary courses forget to mention that it's an approximation - this isn't really a terribly big issue because it's such a good approximation.
So within the null geodesic approximation, light travels the same path regardless of energy. Because the null geodesic approximation is a very good one, we'd expect that any deviations from this, any gravitational wavelength dependent effects, would be very tiny under most circumstances.
Let's add a bit of new material.
The more exact result is the Papapetrou equations for a spinning particle. These can apparently be derived from the dirac equations in curved space-time (with some other assumptions), so I think it's reasonable to apply them to a photon.
http://arxiv.org/abs/0810.0447 (I didn't study this paper terribly closely).
As far as I know, the Papapetrou equations would be the best way to go beyond the null-geodesic approximation.
I'd guess that the effects of a more exact analysis of the departure of photons from null geodesics would break down into some effects that depends on gravitational radiation being emitted by the photon which would probably be energy-dependent, and other effects due to the spin of the photon that probably wouldn't be energy dependent, but I can't really justify this rigorously so take it with a grain of salt.
I don't believe the 2 body problem is solved, in general, for GR, is it?
It depends what you mean by solved. Exact solution for a dynamical case, no; accurate numerical solutions even extreme black hole and neutron star scenarios, yes. N-body problems are not analytically solved in Newtonian theory, but they are analyzed, in practice, all the time.
Sure, I was just trying to say that without resort to numerical simulations of this situation, it seems difficult to give a good answer.
I found a couple of papers discussing and amplifying the old Tolman, Ehrenfest and Podolsky result I mentioned (anti-parallel light beams attract, parallel don't). The first considers the issue strictly classically. The second addresses quantum and spin issues (though published in a major journal, the second has not been cited yet, and I cannot vouch for its reliability; the first is well cited).
http://arxiv.org/abs/gr-qc/9811052
http://arxiv.org/abs/1009.3849
The first paper in my last post provides a cute numeric validation of the normal practice of ignoring these theoretical effects. They compare the impact on two anti-parallel laboratory lasers (10 cm apart) over a 3 km course of their self gravitation, compared to the influence on the beam paths from gravitational waves from the Virgo cluster. The former effect is over 80 orders of magnitude smaller!
GR, as classical electrodynamics, cannot explain the general two-body problem. Both only can deal with two-body problem in certain approximated cases (as when one body is massive).
That's a rather pessimistic way of putting it. Equal mass neutron star binaries are regularly dealt with numerically in the last 10 years or so. Do you have to posit some approximate equation of state for the star? Of course. Does this mean the theory can't deal with it? Not as virtually anyone but you would phrase it.
The literature is filled with references like the following:
http://arxiv.org/abs/1103.3874[EDIT: "can't deal" and "requires approximation" are very different statements. Newtonian gravity requires approximation for the N-body problem. That is very different from saying Newtonian gravity can't deal with the N-body problem.]
pervect said:
Let's recap a bit:
Adding to this nice recap, one way (in principle) light deviates from null geodesics independent of gravitational radiation is simply the analog of two body motion. The moon and Earth versus a satellite and Earth are radically different. Similarly, an enormously energetic photon would be expected to follow a different path near Earth than a low energy photon.
I would not say pessimistic but realistic. GR, as classical electrodynamics, cannot deal with the N-body problem.
Relativistic theories are essentially one-body theories and only can deal with two-body systems in those trivial cases when the two-body system can be somewhat reduced to an one-body problem. I cited a trivial case, that when one of the bodies is massive and the two-body problem is reduced to a trivial one-body problem (external field).
The article that you cite is considering two massive bodies but is working in a special regime where the two-body problem is reduced to solving the (their own words) "effective-one-body" problem. Indeed nowhere in the paper they write a single two-body equation of motion... because does not exist such equation in GR.
This is in contrast with Newtonian gravity, which can deal with the N-body problem. The Newtonian Hamiltonian (or Lagrangian) for a N-body system is well-defined, the N-body equation of motion as well, and the N-body solution can be given in closed form. Of course, although the N-body solution exists in Newtonian gravity, another issue is if you can obtain it in analytical form or if you have a powerful enough computer to obtain a numerical form, but the solution exists by well-established theorems.
I disagree with your interpretation of this paper and papers it references.
First, note that problems setting up well defined N-body Lagrangian is at least annoying, but not necessarily fundamental for a theory. It may be viewed as the failure of the integrability of some systems covered by the field equations. If you declare this to be a requirement for a theory, it is a big problem; if you don't, it is just an issue.
Second, the issue of 'equations of motion' is also not relevant, because it is a feature of GR field equations that these are not needed at all (unlike classical EM). The one body equations are derivable as an approximation from the field equations, but are completely inessential to application of the field equations to a physical scenario (in principle).
Third, the article is comparing numerical evolution from two body initial conditions with analytic one body models as a test on the latter. It doesn't mention two body equations of motion because, indeed, they don't exist but are also unnecessary in GR. Note, for example, this key phrase in the description of the setup of the numerical evolution of the field equations: "As initial data we use quasi-equilibrium binaries generated
with the multi-domain spectral-method code LORENE developed
at the Observatoire de Paris-Meudon [38]"
Is all of this extremely difficult, in practice? Yes. Is it a function of principle (taking a particular classical theory as is, to apply it on its own terms)? No
So, I repeat, GR can handle N body problems, in principle, but the practice is exceedingly difficult.
OP here - thanks to you all for an interesting discussion.
From the authors own abstract:
Following our recent work, we here analyze more in detail two general-relativistic simulations spanning about 20 gravitational-wave cycles of the inspiral of equal-mass binary neutron stars with different compactnesses, and compare them with a tidal extension of the effective-one-body (EOB) analytical model. The latter tidally extended EOB model is analytically complete up to the 1.5 post-Newtonian level, and contains an analytically undetermined parameter representing a higher-order amplification of tidal effects. We find that, by calibrating this single parameter, the EOB model can reproduce, within the numerical error, the two numerical waveforms essentially up to the merger. By contrast, analytical models (either EOB, or Taylor-T4) that do not incorporate such a higher-order amplification of tidal effects, build a dephasing with respect to the numerical waveforms of several radians.
In short, they are studying an effective-one-body (EOB) problem, and comparing numerical simulations of the (EOB) system with both an improved (EOB) analytical model («tidally extended EOB model») and with previous (EOB) analytical models without the improvement.
They find that their numerical simulations can be reproduced with the «tidally extended EOB model». Their result is not a surprise for me, because they are doing numerical simulations of something that is, in essence, an one-body system...
I do not even need to answer the rest of your points :rolleyes: specially since you did not understand what was said before.
It is you that cannot read. Both the abstract and content of the paper say the same. Right from the piece you quotes:
"Following our recent work, we here analyze more in detail two general-relativistic simulations spanning about 20 gravitational-wave cycles of the inspiral of equal-mass binary neutron stars with different compactnesses, and compare them with a tidal extension of the effective-one-body (EOB) analytical model."
They are comparing numeric simulations with an effective one body analytic model to validate the latter. They show one such model is good enough, another is not. The content of this paper shows the same.
There is nothing about numerically evolving the field equations that is limited to any particular number of bodies.
After showing your inability to understand the same reference that you cite, I am not surprised that you cannot understand what I said about fields. What I said has nothing to see with «numerically evolving».
This thread is done for obvious reasons.
Zz.
  • · Replies 19 ·
  • · Replies 35 ·
  • · Replies 51 ·
  • · Replies 27 ·
  • · Replies 30 ·
