New Reply
Converting between bases without base 10 mid-step
Share Thread Thread Tools
Jan26-12, 05:29 PM   #1
I am currently trying to go between any two bases which are between and including base 2 to base 10. (i.e, base 10 to base 3, base 4 to base 6, etc...). Is there an equation or set of formulas for a one-step transition between the bases (or one-way method, rather than converting to base-10 then to base-x.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jan26-12, 06:02 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi smize!
i'm not sure what you're trying to do
there's a general rule that logab = logxb/logxa …
does that help?
Jan26-12, 06:08 PM   #3
Quote by tiny-tim View Post
Yes; I know the general log rules. I am part of the Math Academic team at my school and we are having to convert, for example, 20123 to Base 6. The issue at hand is we, at most, have 45 seconds to do the calculations and guarantee they are correct. We are wondering if there is a way to do this without have to convert it to Base 10 first. A.K.A. is there a direct way to convert between two non-decimal number systems?
Jan26-12, 06:24 PM   #4
Recognitions:
Retired Staff Staff Emeritus
Quote by smize View Post
Yes, there is a way to do this, but all depends on how fast you can calculate.
Let [itex]a[/itex] be your number and let p be the base you want to convert it. Use the division algorithm to write
[tex]a=b_1p+r_1[/tex]
Use it again on [itex]b_1[/itex]:
[tex]b_1=b_1p+r_2[/tex]
Keep doing it until a [itex]b_n=0[/itex]. Then we have
[tex]b_{n-1}=0b_n+r_n[/tex]
Then [itex]r_n...r_2r_1[/itex] is the number you want.
Jan26-12, 06:32 PM   #5
Quote by micromass View Post
you didn't define the division algorithm...And using this, a will have to equal a non base-10 number to another non base-10 number of a different number system.
Jan26-12, 06:52 PM   #6
Recognitions:
http://en.wikipedia.org/wiki/Division_algorithm
Jan26-12, 06:57 PM   #7
Could you give an example of using that to convert between let's say, base 6 and base 4?
Jan26-12, 07:16 PM   #8
Recognitions:
Let's pick 2201 base 4 and let's convert it base 6. So a=2201 and p=12 (remember to express p also in base 4).
2201= 12*103 + 11
122= 12*10 +2
10 = 12*0 +10
Thus 2201 in base 6 is 10 2 11. If we put 10=4 and 11=5, then we get 425.
Jan26-12, 07:21 PM   #9
So the division algorithm does work for all bases, it is just a matter of familiarizing yourself with the multiplication tables of the other bases, correct?
Jan26-12, 07:22 PM   #10
Recognitions:
Correct. And that might be a bit difficult.
Maybe there are other methods, but I doubt it...
Jan26-12, 07:27 PM   #11
it is either that or converting to base 10 then the other bases. In some cases the multiple choice answers we have to choose from are also of 2 different bases -.- And we'll only have 45 seconds to answer.
Feb4-12, 10:04 PM   #12
Recognitions:
converting from power of 2 you just regroup the bits. base 2, 4, and 8 is easy same for base 3 and 9. 67 base 8 to base 2 110 111 then to base 4 11 01 11 or 313
for base 9 to base 3, 87 base 9 is 22 21 base 3
The others are a bit tougher
Feb7-12, 12:02 PM   #13
Thank you coolul007. It is a very interesting method.
New Reply
Thread Tools
Similar Threads for: Converting between bases without base 10 mid-step
Thread Forum Replies
MIPS Help (converting numbers to diff bases) Programming & Comp Sci 5
Converting base 10 to Roman Numerals Introductory Physics Homework 3
Converting between base 7 to 3 Calculus & Beyond Homework 9
Converting rational number to a new base. Linear & Abstract Algebra 6
Number theory, converting numbers too different bases Calculus & Beyond Homework 1
