New Reply
Proving the conservation of momentum when two masses are not equal
Share Thread
Jan26-12, 10:40 PM   #1
In this exercise we used steel and glass balls to calculate and prove the conservation of momentum in elastic collisions. I had to prove how momentum is conserved through displacements vectors and right triangles. All that stuff is easy and I got it. The last question is where I am stuck. The question states: When the mass of the 2marbles (glass and steel) are not the same, and they collide (the glass marble was initially at rest), why do you need to use the formula Pglass = (mglass/msteel) x Vglass (in the brackets the mass of the glass marble is divided by the mass of the steel marble, but we are not given any variables and are just required to prove or derive this formula)?
2. Relevant equations
I attempted to derive this formula through P total initial= P total final and the conservation of kinetic energy. 1/2m1v1i^2(squared) + 1/2m2v2i^2 = 1/2m1v1f^2 + 1/2m2v2f^2
3. The attempt at a solution
when i expand the formulas and substitute them into each other, I just end up with the equations for 1D elastic collisions v1f=(m1-m2/m1+m2)v1i and respectively v2f=(2m1/m1+m2)v1i
I spent the whole night going through all 3 of my physics textbooks and many websites online but couldn't find the way to prove or derive that formula. My teacher said it was a hard question but I never thought it would be this difficult. Oh by the way this is Gr.12 Academic physics.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jan26-12, 10:57 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by Stan2309 View Post
In this experiment you are measuring velocities [by referring to displacement in a fixed time]
You are then trying to show conservation of momentum.
The only measure you have is velocity, but momentum is the product of mass and velocity.
When you do the experiment with two equal steel balls, the mass of a steel ball is effectively just a scaling factor for the velocity - so you can do a diagram of velocity vectors - in arbitrary units - to show momentum is conserved.
When you use balls of different masses [steel and glass], to merely use the velocity of each ball is not suitable.
Since velocity is measured in arbitrary units - displacement / some time (perhaps the time taken to fall a set distance) - and mass is effectively a "scaling factor", we have to match those scaling factors. By using Mglass/ Msteel that is achieved.
or example; if the glass ball is 1/3rd the mass of the steel ball, it will be travelling 3-times a s fast for an equivalent momentum value.
Hope that all makes sense.
Peter
Jan27-12, 04:43 PM   #3
yeah i get what we're doing and all, but my teacher want me to derive this formula. I'm suspecting it has something to do with the glass/steel ratio and the displacement vectors. Need mathematical proof D:
Jan27-12, 04:57 PM   #4
Recognitions:
You will never be able to prove it!!!!
The formula you wrote was:
LHS has units of momentum; because it is momentum.
RHS has units of velocity; because the mass units cancel out.
New Reply
Tags
momentum, proof needed
Similar discussions for: Proving the conservation of momentum when two masses are not equal
Thread Forum Replies
Gravitational Force between two equal masses Introductory Physics Homework 2
Elastic Collision, Equal Masses Introductory Physics Homework 2
2D elastic collisions with equal masses Introductory Physics Homework 23
2D elastic collisions with equal masses General Physics 6
Heat: equal masses of h20 Introductory Physics Homework 7
