Having some issues with a piece of fortran95 code
  • Context: Fortran
  • Thread starter Thread starter charlie87
    Code Fortran95 Issues
The discussion revolves around issues with a Fortran95 code related to calculating aerodynamic properties, specifically maximum camber and thickness distribution for airfoils. Participants are addressing compilation errors, variable declarations, and output formatting within the code.
  • Charlie reports an "Unclassifiable statement" error in the code, particularly with the lines involving DYc and the output statement for X, Yupper, and Ylower.
  • Some participants suggest that variables must be declared before use, indicating that Yc should be an array rather than a scalar, and that using the same name for different types is problematic.
  • There is a discussion about the correct syntax for writing output to files, with suggestions that the WRITE statement needs to be properly formatted to output multiple variables in a single line.
  • Charlie clarifies that the intention was to write multiple variables to a single file and expresses confusion about the output process in Fortran.
  • Another participant emphasizes the need for an output function and suggests that Charlie should research Fortran file I/O for better understanding.
  • Charlie later revises the code and reports that it compiles but encounters issues with one of the calculations not being performed as expected, indicating ongoing troubleshooting.
Participants generally agree on the need for proper variable declaration and output formatting in Fortran. However, there are unresolved issues regarding the specific calculations and the overall functionality of the revised code.
There are limitations regarding the clarity of variable types and the assumptions made about their usage. The discussion does not resolve the specific calculation issue Charlie is facing in the revised code.
charlie87
Hello,
I am pretty new to programming at all and am having some issues with working out why this program is not compiling:
Program MAIN
DO J = 1, 11
K = 10 + J
P = 0.4 !POSITION OF MAXIMUM CAMBER AT 40% CHORD!
M = FLOAT (J + 1)* 0.01 !MAXIMUM CAMBER!
DO I = 1, 11
DO X = 0, 1
DX = 1
IF (X .LT. P) THEN
Yc = (M/(P*P))*(2*P*X-(X*X))
ELSE
Yc = (M/((1-P)*(1-P))*((1-(2*P))+(2*P*X)-(X*X)))
END IF
DYc = Yc(I) - (Yc(I - 1))
FIRST = 0.2969*SQRT(X)
SECOND = 0.1260*X
THIRD = 0.3516*X*X
FOURTH = 0.2843*X*X*X
FIFTH = 0.1015*X*X*X*X
Yt = (T/0.2)*(FIRST - SECOND - THIRD + FOURTH - FIFTH)
THETA = ATAN(DYc/DX)
Yupper = Yc + (Yt*COS(THETA))
Ylower = Yc - (Yt*COS(THETA))
END DO
END DO
WRITE (J, *)
DO I = 1, 11
X(I), Yupper(I), Ylower(I)
END DO
END DO
The code in bold red font are the problem lines and the compiler gives me an "Unclassifiable statement" error for both lines.
Any help would be very much appreciated.
Regards,
Charlie
Technology news on Phys.org
Code:
If you want to use an array in Fortan you have to declare it first, for example
Code:
Program MAIN
DIMENSION Yc(11)
DO J = 1,11
etc
But you have already used Yc as a scalar variable. You can't use the same variable name for two different things.
Code:
I can't even guess what type of Fortran statement that was supposed to be. Neither can the compiler, hence the error message.
Thanks very much for the prompt reply,
The DYc variable i was trying to get was just a delta value of Yc so I thought the I-(I-1) statement mathematically correct.
Also the code:
I wanted the program to write all three variables to the file fort.(I)
sorry again first time coding so have been patching together all the resources I could find.
Regards,
Charles
Also the code:
Then you need to use an output function - WRITE.
Are you trying to write different values to different files? If you don't know that you need to use an output function to do output, you're going to have a really tough time doing output to separate files.
It would behoove you to do some research on Fortran file I/O.
Regards,
Charles
I am trying to write all three variables to one file. then repeat the process 'I' times
I used the write command as shown:
WRITE (J, *)
DO I = 1, 11
So i would have assumed that the code would write to the file fort.(J) the X, Yupper and Ylower values for each 'I' value.
What I am hoping to receive is a number of files of the following format:
I X Yupper Ylower
1 | | |
2 | | |
3 | | |
4 | | |
WRITE (J, *)
DO I = 1, 11
Unfortunately, "assuming" the compiler will guess what your program is supposed to do usually fails. :rolleyes:
In Fortran each WRITE statement produces one line of output. So you need something like
Code:
DO I = 1, 11
WRITE (J, *) X(I), Yupper(I), Ylower(I)
ENDDO
Actually, that won't quite work either, because in your outer loop j goes from 1 to 11, but Fortran reserves a few file numbers for "default" files which read input from the keyboard and write output to the monitor. Those numbers may be 0 1 and 2, or sometimes 5 and 6 (for historical reasons). If you want to create 11 files on disk, the simplest fix for this would be to use file numbers like 11 thru 21 or 51 thru 61 or whatever, which won't clash with anything else.
Thanks for all the responses so far. Right I have reworked my intial code now and have got it to work and compile however I still do have a problem in that one of my calculations is not being carried out.
Code:
DO J = 1, 11
NP = 11 !NUMBER OF POINTS ALONG CHORD!
K = 10 + J !CHANNEL TO WRITE TO!
P2 = P*P !P SQUARED!
T = 0.12 !WING THICKNESS!
PI = 3.1415927
XR = (PI/(NP-1)) !GET RADIAN DISTRIBUTION!
Yc1 = 0 !VARIABLE TO CALULATE DELTA Yc!
NACA = (J*1000)+(P*1000)+(T*100)
WRITE (K,*) 'NACA', NACA
WRITE (K, '(1X,I10, "X", I14,"Y")') 1, 1
DO XT = 1, NP !REPEAT LOOP FOR AS MANY POINTS REQUIRED!
XC = (XR*(XT - 1)) !GET EQUAL SPACING IN RADIANS!
X = ((COS(XC)) + 1) / 2 !HALF COSINE DISTRIBUTION!
X2 = X*X
X3 = X*X*X
X4 = X*X*X*X
IF (X .LT. P) THEN !DECIDE WHICH EQUATION TO USE!
Yc = ((J/100)/P2)*(2*P*X-(X2))
ELSE
Yc = ((J/100)/(1-(2*P)+P2))*((1-(2*P))+(2*P*X)-(X2))
END IF
WRITE (6, *) Yc
FIRST = 0.2969*SQRT(X) !Yt EQUATION BROKEN DOWN!
SECOND = 0.1260*X !Yt EQUATION BROKEN DOWN!
THIRD = 0.3516*X2 !Yt EQUATION BROKEN DOWN!
FOURTH = 0.2843*X3 !Yt EQUATION BROKEN DOWN!
FIFTH = 0.1015*X4 !Yt EQUATION BROKEN DOWN!
DYc = (Yc1 - Yc)
DX = 1
Yc1 = Yc
WRITE (K, *) X, Yupper, Yc
END DO
DO XT = (NP-1), 1, -1 !REPEAT LOOP FOR AS MANY POINTS REQUIRED!
X2 = X*X
X3 = X*X*X
X4 = X*X*X*X
IF (X .LT. P) THEN
ELSE
END IF
WRITE (6, *) Yc
DYc = (Yc1 - Yc)
DX = 1
Yc1 = Yc
WRITE (K, *) X, Ylower, Yc
END DO
END DO
END PROGRAM
The Yc variables are always set to zero and I can't figure out why. All the components are ok and so the calculations should be ok. any help would be greatly appreciated.
Regards,
Charles
Variables with names starting with the letters I thru N are integer variables.
J/100 is dividing an integer by an integer, and Fortran gives the result of that as an integer. J/100 will always equal = 0 if J is less than 100. You can fix this with
Yc = ((J/100.0)/P2)*(2*P*X-(X2))
Dividing an integer by a real constant (written with a decimal point) will give a real result, which seems to be what you want.
Or you could write
Yc = ((J/(100*P2))*(2*P*X-(X2))
100*P2 is an integer times a real which gives a real value. Then J / (real value) gives another real value.
AlephZero,
Thank you very much that is absolutely perfect. I thought it would be a simple solution but just could not see it myself.
Thank you again for all of your help.
I have another hopefully simple to answer problem. In my code I have got it to calculate x values from 0 - 1 in decimal values and the y values associated with these. I than print off the values straight away and progress the x value so i end up with a table like so:
NACA 2412
X Y Z
upper surface
1.0000000 0.0000000 0.0000000
0.97552824 0.0000000 5.01149474E-03
0.90450847 0.0000000 1.86340362E-02
0.79389262 0.0000000 3.72849256E-02
0.65450847 0.0000000 5.64936101E-02
0.49999997 0.0000000 7.17544481E-02
0.34549147 0.0000000 7.87679926E-02
0.20610739 0.0000000 7.27545992E-02
9.54914838E-02 0.0000000 5.43368347E-02
2.44717114E-02 0.0000000 2.82343049E-02
1.91068949E-15 0.0000000 7.78673392E-09
lower surface
0.97552824 0.0000000 -1.81513163E-03
0.90450847 0.0000000 -6.91501191E-03
0.79389262 0.0000000 -1.45239700E-02
0.65450847 0.0000000 -2.36907862E-02
0.49999997 0.0000000 -3.28655615E-02
0.34549147 0.0000000 -3.95107903E-02
0.20610739 0.0000000 -4.21531908E-02
9.54914838E-02 0.0000000 -3.75181958E-02
2.44717114E-02 0.0000000 -2.34896801E-02
is there a way that I can get the lower surface results to be displayed in reverse order (from 0 to 1) the code will not allow me just do
do 11, 1, -1
as the equations used do not have the sufficient variables in this direction.
should I save the x and y values to an array and then get the array to be read and printed backwards? if so how do i do this.
I have attached my revised code.
