Is the above relation a function?
  • Thread starter Thread starter aisha
    Function Relation
The discussion centers on determining whether a given relation represented by a graph is a function. Participants confirm that the relation fails the Vertical Line Test, indicating that it is not a function since a vertical line intersects the graph at multiple points. Additionally, it is concluded that the inverse of the relation also fails to be a function, as it does not pass the Horizontal Line Test after a 90-degree rotation of the graph.
  • Understanding of the Vertical Line Test for functions
  • Knowledge of the Horizontal Line Test for inverse functions
  • Basic graphing skills to visualize relations
  • Familiarity with function notation and terminology
  • Study the properties of functions and their inverses
  • Learn about the implications of the Vertical Line Test in detail
  • Explore the Horizontal Line Test and its significance in determining function inverses
  • Practice graphing various relations to identify functions and their inverses
Students in mathematics, educators teaching algebra concepts, and anyone interested in understanding the fundamentals of functions and their properties.
aisha
X X X
X
X
X
X
X
X X X
These are the points on my graph. The question says is the above relation a function? I think this is a function, but I don't know how to justify my answer.
Also it says is the inverse of this a function? How do I know? I am thinking no because f(x) is already a function so it won't pass the horizontal line test, therefore the inverse will not be a function.?? Help me out please. :confused:
The Vertical Line test. If you can draw a vertical line through any point in the graph and it goes through two points, it's not a function. Otherwise, it IS a function. From your graph, it looks like it isn't a function since drawing a vertical line would result in more than one y result.
Also, judging from your graph, when you rotate it 90 degrees and use the vertical line test, it should also fail, meaning that both the function and its inverse aren't functions.
Thanks I got it. :smile:
