Maximizing DC Motor Performance: Voltage and Amp Considerations Explained
  • Thread starter Thread starter grandad_legin
    Dc Dc motor Motor
The discussion revolves around the performance characteristics of a DC motor, particularly focusing on the effects of voltage and current on torque and speed. Participants explore how different power sources might influence motor behavior in practical applications, including the use of a gearbox.
  • One participant inquires whether using a 20-volt charger instead of a 12-volt charger would increase the motor's power or simply increase the speed of the output shaft.
  • Another participant clarifies that the current drawn by the motor is determined by the load, indicating that a higher-rated power source does not force the motor to draw more current than it needs.
  • A response suggests that increasing voltage can lead to both higher speed and torque, depending on the load applied to the motor.
  • A metaphor involving a water wheel is used to illustrate the relationship between voltage (pressure) and current (flow), explaining how they affect motor performance under different loads.
  • Participants discuss rules-of-thumb regarding electric motors, including the relationship between voltage, current, torque, and RPM, and the implications of no-load and loaded conditions.
  • One participant mentions the potential use of variable resistors or electronic speed controllers to manage motor speed and current effectively.
Participants express varying views on the relationship between voltage, current, torque, and speed. While some agree that increasing voltage can enhance performance, the exact effects under different loading conditions remain a topic of discussion without a clear consensus.
Participants acknowledge that the performance of the motor is contingent on various factors, including load conditions and the specifications of the power source. There are unresolved aspects regarding the optimal management of voltage and current for desired motor performance.
This discussion may be useful for individuals interested in understanding the operational characteristics of DC motors, particularly in applications involving variable loads and power supply considerations.
grandad_legin
Hi - can someone please help me with the following - I am mechanically minded not elecrically so please do not pick on me - I purchased a DC motor and gearbox (worm and wheel) from ebay (item 3858047682 if you want to look at it) - now it is supposed to work at up to 20 volts DC - now I was going to use a standard 4 amp 12 volt car battery charger to power it - what I do not know is -
(1) if I used a 20 volt charger instead would it make the motor more powerfull as regards torque or just make the motor spin quicker thus making the gearbox output shaft spin quicker -
(2) as I do not particularly want the output shaft turning faster would using a 12 volt 12 amp rather than a 4 amp battery charger produce more torque or would this not be of any benefit.
I know I can increase the torque by feeding the output shaft into another gearbox or pair of pulleys to increase it but this is going to take up more room than I want to in the unit
Thanking you in anticipation of your help - legin
Amps are drawn. If you hook a load to a 12 volt 10 amp source and it only draws 1 amp it doesn't matter how many amps the source is rated at as long as it is 1 or above.
Averagesupernova - thank you 4 replying - I realize what you say is true - i.e. my light bulb only draws what it needs not the whole 5 amp supply it is being fed by - but can you answer the rest of the question please relating to the torque - if a dc motor is supplied by 12 or 20 volts - does applying the increased voltage to the motor make it a more powerful motor or just make the ouput shaft turn faster? thanks - legin
It does both, depending of course on how you load it. If you need more torque, use more voltage (as long as your source can handle the extra current). Also note that the motor will require much more current if it is exerting a torque on something rather than just freely spinning.
I'll try to convert this over to a physical metaphor. You build a small water wheel with some soup ladels arranged like a kids pinwheel. You spin the water wheel with a nozzle on a garden hose and it can spin quite fast. The more pressure you apply the faster the wheel spins.
Now you take the axle spun by the water wheel and attach a load to it, maybe a string pulling up a weight. It cannot spin as fast anymore, but you find the more pressure you apply the faster it can spin. But if you lower the pressure it quickly reaches the point where it can't spin at all. If you remove the load and apply the same pressure it will spin at a speed that seems to fit the pressure. Even light loads are important to find the RPM based on the pressure.
Now let's say you attach a very large load to the axle spun by the water wheel. You cannot make it spin with your garden hose so you get another. Even 2 can't so 3, 4, 5, 6 - they're so big a stream of water it can't even all hit the soup ladels anymore and it still cannot spin. If you have a firehose you have so much pressure and volume you could make it spin but might damage the whole setup if not careful.
Ok, the pressure=voltage and the quantity of water is current. And from the above example, at a given pressure once you have reached a certain quantity of flow, any additional quantity does not change anything and is not used. At a higher rate of pressure that additional flow could easily be used to produce more work.
Quick rules-of-thumb on electric motors that are true enough to illustrate the relationships.
No-load full RPM is limited by voltage. More voltage means faster no-load RPM.
power input = current times voltage
Max current flows at stall (zero RPM) and can quickly burn up motors and supplies/batteries
Roughly the same torque is produced from stall to 1/2 max RPM and then falls to zero torque at max RPM.
power output = torque times rpm
1/2 no load RPM is max efficiency (least amount of power input for power output)
1/2 voltage = 1/4 power
Its difficult to manage no-load RPM and loaded RPM to be the same without fancy circuitry. In between min/max it could be the voltage OR current limiting it from spinning as fast as you'd like. It changes at different RPMs since at full speed you need more voltage to go faster and near stall you need more current to go faster.
You might find an old light dimmer or variable speed electric drill trigger that could be used as a variable resistor to wire in series to your motor from the supply. You could then limit the voltage to control your RPM. But this will also limit the current and is a catch 22 and you can see the available power drops quickly.
The best electronic speed controllers limit the current sent to a motor to avoid burning up the supply (at stall the current can go into the hundreds and burn up everything) and then control the "average" voltage seen by the motor through very fast switching.
Cliff
Thank you both
Stingray and Cliff J - thank you both for answering this thread - especially as you did not take the P--S - both of your answers have helped but Cliff J has put it in such a way that it is very easy for me to understand and I am very pleased he took the time to write all that out for me - because of this I can now close this thread - thank you both very much indeed - grandad_legin
  • · Replies 17 ·
10K
