How Do I Find the Gradient of y=\frac{5x-4}{x^2} at the X-Axis Crossing?
  • Thread starter Thread starter footprints
    Curve Gradient
The discussion revolves around finding the gradient of the curve defined by the equation y=\frac{5x-4}{x^2} at the point where it crosses the x-axis. Participants are exploring the differentiation of the function and the conditions for determining the x-intercept.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the process of differentiating the function to find the gradient and question the correctness of their calculations. There is also a focus on substituting y=0 to find the x-intercept and verifying the results.
Some participants have confirmed their derivative calculations and are discussing the values obtained for the x-intercept. There is acknowledgment of potential errors in calculations, and participants are sharing their results to compare and clarify their understanding.
Participants are working under the constraints of homework rules, which may limit the extent of guidance provided. There is a focus on ensuring that the correct approach is taken to find the x-intercept and gradient without providing complete solutions.
footprints
Find the gradient of the curve [tex]y=\frac{5x-4}{x^2}[/tex] at the point where the curve crosses the x-axis.
After I differentiating the equation, I got [tex]-\frac{5}{x^2} + \frac{8}{x^3}[/tex] (it might be wrong). Now what do I do?
Well, dy/dx gives you the gradient at x. The curve crosses the x-axis when y = 0. You've worked out the derivative correctly though.
I thought so too. But I couldn't get the right answer.
What answer did you get?
[tex]3\frac{1}{8}[/tex]
Can you post your working? I got dy/dx = 7.8125. Also, what value did you get for the x intercept?
To get x I must substitue y=0 into [tex]y=\frac{5x-4}{x^2}[/tex] right?
Btw the answer my book gives me is the same as yours
Yes, then solve for x.
y = (5x - 4)/x^2
=> (5x - 4)/x^2 = 0
Need to solve for the numerator being equal to 0, so x = 4/5.
Thats great. Then I plugged in 4/5 into
[tex]-\frac{5}{x^2} + \frac{8}{x^3} \rightarrow -\frac{5}{\frac{4}{5}^2} + \frac{8}{\frac{4}{5}^3}[/tex]
Then I solve and get [tex]3\frac{1}{8}[/tex]
Oh now I know why I didn't get the answer. I calculated a part wrong. Sorry. Thank you for your time.
No problem :smile:.
  • · Replies 19 ·
  • · Replies 16 ·
