Torque equation of an electric motor
The torque equation for an electric motor is derived from the Lorentz force law, specifically using the relationship F = IBxL. The force per unit area is expressed as F/wL, simplifying to F = BA. The overall torque equation is established as T = BA x 2∏rL x r, where r is the rotor radius. The discussion highlights confusion regarding the current being equal to wA, emphasizing that the force on a current-carrying conductor is dependent on the length and area of the conductor.
  • Understanding of the Lorentz force law
  • Familiarity with electric motor components, specifically rotors and coils
  • Knowledge of torque calculations in physics
  • Basic principles of electromagnetism
  • Study the derivation of the Lorentz force law in detail
  • Research the relationship between torque and magnetic fields in electric motors
  • Learn about the effects of coil turns (N) on torque production
  • Explore the impact of angle (θ) between magnetic fields and coils on torque
Electrical engineers, physics students, and anyone involved in the design and analysis of electric motors will benefit from this discussion.
fonz
The example I am looking at in my textbook starts by considering and area of the rotor surface of width w and length L.
Then the axial current flowing in the width w is equal to I=wA which is exposed to a radial flux density B
So from the Lorentz force F=IBxL the equation becomes
F= wABxL
so the force per unit area is F/wL which becomes:
F=BA
Then to obtain the torque the force per area is multiplied by the entire area of the rotor (2∏rL) then multplied by the radius of the rotor
So the overall torque equation becomes:
T=BA x 2∏rL x r
What doesn't make sense is how can the current be equal to wA? by the Lorentz equation the force on a current carrying conductor is IBxL so the width and area of the conductor carrying the current I does not matter? so why does it apply here?
Regards
Dan
I agree with you. Without seeing any diagram I would say the force on the side of the coil of length L will be BIL. The torque produced by the coil will be BILd where d is the separation of the sides of length L. Ld is the area of the coil.
If the coil is in a uniform field then the torque will be BIASinθ where θ is the angle between the field and the normal to the plane of the coil.
If the coil has N turns then the torqe is BNIASinθ
I don't understand what seems to be in your book !
hope this is some help
9K
