Question of Relativity and the Speed of Light?
The discussion centers around the effects of traveling at light speed on the passage of time, specifically how much time would pass for a traveler compared to a stationary observer. The scope includes theoretical implications of Special Relativity and mathematical reasoning related to time dilation.
  • Technical explanation, Mathematical reasoning
  • One participant inquires about the equation to determine the time experienced by a traveler moving at light speed for 10 years relative to a stationary observer.
  • Another participant provides the equation τ=t√(1-β²) for calculating the traveler's time (τ) based on the stationary time (t) and the speed as a fraction of the speed of light (β), noting that β can range from 0 to just below 1.
  • The same participant emphasizes that using a speed of 1 (the speed of light) in the equation yields nonsensical results, suggesting that only speeds less than light are valid inputs.
  • A later reply confirms that it is indeed thought impossible to reach the speed of light, reinforcing the earlier point about the equation's limitations.
Participants generally agree on the mathematical formulation related to time dilation and the impossibility of reaching the speed of light, but the discussion does not explore deeper implications or alternative models.
The discussion does not address potential limitations of the equation in terms of practical application or the assumptions underlying Special Relativity.
WLatourelle
Is there an equation to figure out how much time would pass traveling light speed for 10 years relative to the person traveling? I know its less, but by how much exactly?
Yes, the equation is τ=t√(1-β2) where τ (tau) is the time for the traveler, t, is the time in the stationary frame, and β, beta, is the speed you want to travel as a fraction of the speed of light and can have a value from 0 up to but not including 1 (which is the speed of light). If you pick a speed of 1, then you get the same answer no matter what t is which doesn't make any sense. But pick any smaller value and you can use the equation. This equation was published by Einstein in his famous 1905 paper introducing Special Relativity near the end of section 4.
Thank you, that is just what I was looking for. But just to be clear it doesn't make any sense to input the speed of light and above because it's thought impossible to reach, correct?
Correct.
  • · Replies 25 ·
  • · Replies 93 ·
  • · Replies 26 ·
  • · Replies 42 ·
  • · Replies 19 ·
