New Reply
Simple Harmonic Motion!?
Share Thread Thread Tools
Jan30-12, 02:06 PM   #1
Hi All,
New to the forum, sorry if this is a thread that has been discussed before, however I've had a quick look and have been killing myself for days over this.
Approached my college tutor today and he couldnt explain it!?
I'm almost sure that it is something easy and simple, but as it stands at the moment, I cant see the light!
Ok, the question...
I understand that SHM can be thought of as circular motion, I have read through the derivations, beginning with the centripetal acceleration equation a=ω^2r (r as radius)....and ending with with the SHM equation of motion a=-ω^2x
My problem is that my book says the ω in the SHM equation is "a positive constant with units of s^-2", which I understand is Hertz^2 right?
At what point and how does the ω change from rad/s to s^-1?
(I know there is a relation between the two, however as far as I could see on the internet, a hertz is a cycle per second, but that means per cycle there is 2∏ rad/s? So they arent equivalent...)
Also, I found the equation ω=√k/m is the equation to find angular frequency?
Whats the relation between angular frequency, angular velocity, hertz considering they are all s^-1?
The other problem relating to this I have is the fact that when looking for the period of motion of a circle the equation is T=2∏/ω......where ω is the angular velocity.
and...the period of motion of an oscillation is T=2∏/ω but here ω is in hertz?
Very sorry if this is confusing or that its a ridiculous and stupid question, I'm sure you've all had that Math/Physics block at some point where you just cant see it at first....
Please explain all you can, bare in mind I'm fairly new to Physics, so dont hit me with hugely complicated stuff if it can be helped.
Much appreciated if anyone can help!
Thanks.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Jan30-12, 02:21 PM   #2
I think your problem here is to do with units.
Frequency Is measured in Hertz but the unit of Hertz is s^-1
this is because part of the unit is a pure number. 1 Hertz means 1 cycle per second
In the same way 'radian' is not a 'unit'......it is a pure number because it is a ratio of 2 distances.
So an angular velocity of 1radian per sec has units of 'per sec' or s^-1
Jan30-12, 02:51 PM   #3
Welcome to Physics Forums H4H.
Are you sure your book says this and not that
ω2 has units s-2?
The dimensions of ω are the reciprocal of time ie T-1
Note I have said dimensions, not units.
You should distinguish between these.
One foot and one metre are both units of length, which has dimension - L.
Jan30-12, 03:09 PM   #4
Ok so are they essentially the same thing it just depends on the system in which you're observing?
Radian being the ratio of angle turned through in relation to the radius?
So you could effectively write that the angular velocity of a car is 6 s^-1 but the radians is put there to give more information?
So "omega" has different dimensions, all of which are reciprocals of time?
Sorry if I'm completely not getting the obvious, it's frustrating hitting a mental block on something I can see is probably simple.
Jan30-12, 03:16 PM   #5
You have got the idea!! When you say 'angular velocity is 5 radians per second' it means something different to saying ' a frequency of 5 hertz' (this means 5 revolutions per sec)
BUT both have units of s^-1 (and dimensions of T^-1if you find yourself involved in dimensional analysis)
Jan30-12, 03:28 PM   #6
Ok feeling closer to the truth now.
But I thought there were 2pi radians in a revolution, therefore the rad/s will be higher than the Hz?
Does this not mean that the two can't be equivalent as one has to be 2pi x more than the other?
Most obvious example for me is the equation for the period of motion/oscillation, how can they both have the same equation, but different "omega" (angular and Hz) values with one 2pi x more than the other?
That looks confusing now I've written it out.
You're helping a lot more than my tutor did though so thanks!
Jan30-12, 03:35 PM   #7
What you have met here is common in physics.
A good example is force x distance which has units Nm
Force x distance can mean 'work done' and then Nm are given the special name 'Joules'
In equilibrium applications Force x distance can be called 'turning effect' or 'moment' or 'torque' or 'couple' the units are Nm but are not given a special name.
Having a feel for units ....( or dimensions)....... Can be a great help in physics.
Jan30-12, 03:38 PM   #8
What you have just written is covered by
T = 2∏/ω
Can you see it?
And f = 1/T = ω/2π
Jan30-12, 03:54 PM   #9
I kind of see what your saying, I hadn't thought of it in that way.
But with work done and turning moment, there is no difference in size like there is between a radian and a cycle?
All force is measured in newtons regardless of where it is...
If you have a question asking for the omega value of an oscillating system, you use the omega=2pi/T
You get s^-1 as your unit?
You use the same equation to find the omega value given a question asking about circular motion, omega=2pi/T and your given units in rad/s?
How can that be when rad/s is 2pi x bigger than Hz?
Sorry about this dude, must be boring going over basics like this.
Jan30-12, 04:28 PM   #10
I take your point about force x distance !!!
You say rads/sec is 2pi x bigger than Hz is very wise......you have got it
'rads' is not a unit !! So 'rads/sec' is only /sec or s^-1
and Hz is cycles per sec......cycles is not a unit so Hz is only /sec or s^-1
So omega = 2pi x f
( it is not boring!!!)
Jan30-12, 04:36 PM   #11
Sorry to be boring but rads or radians are a unit - they are just dimensionless, like all angles.
Jan30-12, 05:34 PM   #12
(Pre-warning: I'm not even sure these questions are making logical sense anymore.)
But if in circular motion ω=2∏/T (when looking at the period of motion) the omega is defined as angular velocity which is the change of radians over time .... ω=Δθ/t....you see the circle, you see the number of radians that are turned through per second...
However in SHM ω=2∏/T (again when looking at period of motion) the omega here is in cycles per second? A cycle which is larger than a radian....
But during the derivation of the SHM equations, you use circular motion equations, the ω starts out in rad/s (a=ω^2r) and ends up as s^-1 (a=-ω^2x) without anything being done to it?
How when rad/s ≠ s^-1 in terms of actual values, 1 rad/s ≠ 1 s^-1?
Or is it that I shouldnt be looking at numbers?
(Argh head is jumbled!)
In terms of units, I see that... rad/s = /s because a radian is not a unit in the sense that it has no definite value, if thats right? (Always dependent on the size of the cirlce yes?)
Likewise I assume the same is true for a cycle/s = /s because a cycle again will be dependent on the size of the circle? Not definite?
Whereas something like a m/s ≠ /s because a metre is a unit, has a definite value?
Or looking at N/m again, definite values?
Am I on the right track with that?
(Just as a note, I think you've pretty much made me understand it, I'm just trying to clear things up in my head now....and test you at the same time!)
Thanks for your time so far!
Jan30-12, 05:43 PM   #13
I'm sorry no definite value?
You are confusing 'units' which are a system of measure of a particular quantity and 'dimensions' which have (fundamental) physical significance. There are many quantities in Physics that are dimensionless, but they all have units and if we change these units we change the number.
So for instance 1 radian is about 57.3 degrees. Clearly neither are the same number but both definite and both refer to the same angle.
Equally I metre is about 3.3 feet, both refer to the same length, but the units are different so the numbers are different.
Jan30-12, 05:46 PM   #14
Recognitions:
Gold Membership Gold Member
Quote by Hunt4Higgs View Post
However in SHM ω=2∏T (again when looking at period of motion) the omega here is in cycles per second?
No, ω is radians per second, we just don't usually bother to write the "radians". There is a cycles per second, usually denoted f, but that's not what goes into the formulas you've been writing. For example, the solution usually looks something like cosine(ωt) or cosine(2∏ft), but not cosine(ft). The cosine function is cyclic over 2∏, not over integer entries.
Jan30-12, 06:09 PM   #15
I'm clearly not getting this the way I should be.
How were you guys taught it?
Should I try and look at the "dimensions and "units" you mention?
Should I just accept that when looking at SHM the ω is given in the units /s?
....and when looking at circular motion the ω is given in the units rad/s?
Is it stupid to keep asking why when I'm at the low level that I am?
Jan30-12, 07:23 PM   #16
I suppose what you are really asking is
Why do we bother to introduce ω at all?
Well look at the attached sketches.
The first shows something going round and round in a circle with constant velocity.
The second shows a pendulum swinging back and fore between A and C. Note the velocity is not constant.
They have, however, something in common.
Both are repetitive motions. Each pursues the same path over and over again in the same time interval. The time interval for each is not necessarily the same, but we can make it so.
The repetition occurs when the object passes through the same point going the same way. The time interval between successive occurrences is called the period.
So the circular motion passes through A once every complete circle.
This is 360 degrees or 2π radians. If this takes T seconds we say that is has an angular speed of 2π/T radians per second.
So the equation of motion connecting distance and time is
d = QPt where Q is a constant, equal to 2π/T, P is a constant (=radius)
The pendulum starts from B, goes through A and back to B in the opposite direction and then to C and then back to B again in the original direction, in its period T.
Because it is travelling with SHM the distance it travels in some time t is given by, ie the equation of motion for SHM connecting distance and time is
d = Psin(Qt), where P and Q are constants.
Now to make the connection.
It turns out that the constant Q is also given by 2π/T; Pdetermines the amplitude of the SHM and is equivalent to the radius in the circular formula.
If we compare this with the formula for circular motion we can see that they are the same so we say that SHM proceeds with and angular velocity of 2π/T.
However because we are lazy and don't want to write this fraction every time and because it occurs in lots more useful formulae we give it its own letter ω.
Depending upon your level of maths you may be able to see that this coincidence is no accident but occurs because sin(t) is a function which repeats every 2π radians or 360 degrees.
If you then ask why do we use radians at all, well one justification is that there are lots of formulae in physics involving sin(θ) where we can make the approximation that for small angles sin(θ) = θ so long as we measure angles in radians.
Does this help?
Jan31-12, 06:00 AM   #17
Ok I think thats cleared it up a lot more. Thanks.
So just to check, if the system is exerting SHM but the movement is linear (rather than angular like the circle or pendulum), is the ω still rad/s?
As isnt the frequency, denoted f, in the units /s?
Is the ω just another letter in place of f? As both are looking at SHM, both looking at cycles, and both have the units /s in SHM?
The acceleration equation describing SHM.....a=-ω^2x
As you said earlier Studiot, the book says ω^2 ...units = (s^-2) but the derivation of this equation starts with circular motion and the centripetal acceleration a=ω^2r where the omega has units (rad/s).
New Reply
Tags
angular, classical, frequency, harmonic, motion
Thread Tools
Similar Threads for: Simple Harmonic Motion!?
Thread Forum Replies
What is the connection between simple harmonic motion and pendulum motion? Introductory Physics Homework 7
Pendulum/Simple Harmonic Motion, what is its energy of motion? Introductory Physics Homework 10
Using Simple Harmonic motion and conservation of motion to find maximum velocity Introductory Physics Homework 3
Is a simple pendulum simple harmonic motion? Introductory Physics Homework 2
Simple Harmonic Motion- From Uniform Circular Motion Introductory Physics Homework 5
