Find Parametric Equation for Line Parallel to Two Planes
The problem involves finding parametric equations for a line that passes through the point (1, 2, 3) and is parallel to two given planes: 3x + y + 5z = 4 and z = 1 - 2x. The original poster expresses uncertainty about their solution compared to a reference from a book.
  • The original poster attempts to derive the direction vector by ensuring orthogonality to the normals of the planes. They use dot products to set up equations and find a direction vector. Some participants suggest using the cross product of the normals for a direction vector, while others question the clarity of the book's answer and its relevance to the original problem.
The discussion is ongoing, with participants exploring different methods to find the direction vector. There is acknowledgment of potential confusion regarding the book's answer and its applicability to the original question. Some participants express uncertainty about the correctness of their approaches and the information provided.
Participants note discrepancies between their findings and the book's answer, leading to discussions about possible errors in the book or misunderstandings of the problem. There is mention of the possibility that the book's pages were uploaded incorrectly.
knowLittle
Find parametric equations for the line which passes through the point (1; 2; 3)
and is parallel to both of the planes 3x + y + 5z = 4 and z = 1 -2x.
I have seen the result for this problem, but it's different than mine. I'm not sure, what I'm doing wrong. Please, help.
If the line is parallel to two planes, then the line must be orthogonal to both planes' normals.
First, I notice that the planes' normal are:
n1=(3,1,5) and n2=(2,0,1)
Then, the direction vector of the line is p=<a,b,c>
and since, the vector and the normals are orthogonal.
*Dot Products*
p.n1=0
p.n2=0
I get :
3a+b+5c=0
2a+0+c=0
Using determinants, I find that the direction of the line is: 1i+7j-2k
{x-x_{1}} over {1} ={y-y_{1}} over {7} ={z-z_{1}} over {-2} =t
or
(x-1)=(y+2)/7 =(z-3)/-2 =t ...where the values of the point passed are plugged in on the numerator.
So, my parametric equation yields:
x=t+1
y=7t-2
z=-2t+3
welcome to pf!
hi knowLittle! welcome to pf! :smile:
x=t+1
y=7t-2
z=-2t+3
looks ok (apart from the -2 in the y) …
maybe the book is using a different parameter (eg t+1)
what answer does the book give?
And you might notice that a quick way to get a direction vector along the line of intersection is to take the cross product of the normals.
This is the book's answer. It's very short and unclear.
1a: Take cross products of the displacement vectors to get a normal to plane P:
Cross [{0, 1, 2} - {1, 0, -1} , {1, 2, 3} - {0, 1, 2}]
{-2, 4, -2}
That gives an equation of the plane from the normal vector and a point:
-2x + 4(y - 1) - 2 (z - 2) ==0
-2 x + 4 (-1 + y) - 2 (-2 + z)==0
Also, I don't see any problem in the substraction of "2". It's the result of the determinant.
I'm confused … that seems to be a different question :confused:
I don't understand the cross product shown on the book.
My cross product of the normals give: 1i+ 7j-2k , where normal1=<3,1,5> && normal2=,2,0,1>
I think that you are right. The pages, where uploaded incorrectly by the staff. Wow.
Thank you all.
I think that you are right. The pages were uploaded incorrectly by the staff. Wow.
Thank you all.
