Prove similarity (leading to a Pyth. proof)
  • Context: Undergrad
  • Thread starter Thread starter DEMJR
    Proof
The discussion revolves around proving the similarity of triangles ACD and CBD to triangle ABC, using geometric principles. Participants explore the relationships between angles and sides, referencing the Pythagorean theorem and Euclidean geometry.
  • One participant asserts that they can prove corresponding angles are congruent for triangles ABC and CBD, suggesting that this may imply similarity.
  • Another participant questions whether the established angle congruences are sufficient to prove similarity, indicating uncertainty about the implications of their findings.
  • Some participants propose that the Pythagorean theorem is related to the concept of similar triangles, suggesting that proving one can lead to the other.
  • A participant emphasizes the need to define similarity in terms of proportional sides, referencing Euclidean definitions and the concept of area.
  • There is mention of the Archimedean axiom and its relevance to defining proportionality without using real numbers, highlighting the complexity of the topic.
  • Another participant points out that the assumption of the sum of angles in a triangle being 180 degrees is contingent on the truth of the Pythagorean theorem.
  • Some participants reference external sources, such as Wikipedia and Euclid's Elements, to support their arguments about similarity and proportional sides.
Participants express differing views on the sufficiency of angle congruences to establish similarity, with some asserting it is adequate while others disagree. The relationship between the Pythagorean theorem and triangle similarity remains contested, with no consensus reached on how to approach the proof.
Participants highlight the need for clear definitions of similarity and proportionality, as well as the implications of different geometrical frameworks (Euclidean vs. non-Euclidean). There are unresolved assumptions regarding the use of the Pythagorean theorem in proving similarity.
DEMJR
CD is a perpendicular from C to AB. Prove that triangles ACD and CBD are both similar to triangle ABC. (See attached image)
I can prove corresponding angles are congruent very easily for ABC and CBD. For example, angle A = angle A for both ABC and ACD. Also, angle D = angle C since ABC is a right triangle and CD is perpendicular to AB. Lastly, angle ACD = 90 - angle DAC and angle ABC = 90 - angle DAC. Therefore, angle ACD = angle ABC. Thus all three corresponding angles are congruent.
For showing that the sides are proportional, I have no clue. What confuses me is what c represents. I am guessing it is supposed to represent AB. If it does, then what in the world is AD supposed to be? Or if c represents AD then what is DB supposed to be? Thanks for all your help.
Tell me if I have started on the wrong foot or if I am way off in my approach. Any feedback is welcome.
Welcome to PF!
Hi DEMJR! Welcome to PF! :smile:
Perhaps I'm forgetting my Euclid, but doesn't that prove they are similar? :confused:
Similar triangles is equivalent to the Pythagorean theorem. When two triangles have the same angles then their corresponding sides have the same ratios.
In Euclidean geometry shape is scale invariant. This is not true of hyperbolic and spherical geometry.
The proof you want to try is to show that the Pythagorean Theorem implies similar triangles and the converse, that similar triangle implies the Pythagorean theorem.
Also show that the parallel postulate is true only when these are true,
Yea it definitely doesn't prove that they are similar.
I cannot use the pythagorean theorem to prove this. I must show that the both of the inscribed triangles are similar to ABC using the sides a, b, and c. I just have no clue on how to begin to show proportionality of the sides (I have already shown corresponding angles are equal). What I think this problem is building towards is what you said that similar triangles implies the pythagorean theorem but I don't think I am supposed to use the pythagorean theorem to prove anything. Just show similarity using the given information.
You have to define what similarity means. I.e. if AB, CD, XY, ZW are line segments, you have to define what the equation AB/CD = XY/ZW. Equivalently, you have to define the equation (AB)(ZW) = (XY)(CD), i.e. you have to define an equality of products of line segments.
One way to do this is to say that a product of line segments represents the area of the rectangle with the segments as sides. Then you have to prove that the rectangles with sides (AB) and (ZW) has the same area as the one with sides (XY) and (CD).
When these segments represent corresponding sides of a triangle with the same angles, one way to prove this is to note that the triangles can be placed in a circle so that they are produced by two intersecting secants of the circle. Then Proposition III.35 of Euclid implies the rectangles they determine have the "same area", in the sense of equi - decomposition. This proof uses pythagoras, as lavinia has said.Euclid's own proof is different and makes an additional assumption, that any two segments considered can be used to measure each other. I.e. that there exist integers n,m such that n times one segment exceeds the other, and m times the other exceeds the one. This is called Archimedes axiom, although Euclid specifically mentions its necessity.
Then since we know what it means to multiply a segment by an integer, Euclid defines in chapter 5, the equation (AB)/(CD) = (XY)/(ZW) to mean that for every pair of integers n,m
we have (AB)/(CD) ≤ n/m if and only if (XY)/(ZW) ≤ n/m. Of course here,
(AB)/(CD) ≤ n/m, means that m(AB) ≤ n(CD). This last statement makes sense because we know how to multiply a segment by an integer.Euclid then painstakingly uses the theory of area to prove similarity in this sense in Proposition VI.4. Then he proves the result you ask about in Prop. VI.8.
The fact he does not use the earlier result of Prop. III.35 to obtain similarity in an even stronger sense than here makes me wonder if the same person who wrote book III, also wrote books V and VI.
It is often asserted that the theory of similarity should be sued to prove pythagoras, but this is circular in some presentations, since in Euclid pythagoras is used to develop the theory of similarity. Indeed similarity can be developed without pythagoras, but it is a bit of trouble to do so. This is achieved nicely in Hartshorne's geometry, euclid and beyond.
After using Pythgoras to develop similarity Euclid does give a second proof of pythagoras using similarity.
Wikipedia says that if the angles of a triangle are equal then that is one of the definitions of similar. This must be your answer because without some theorem such as the Pythagorean theorem you can not say anything about the ratios of the corresponding sides.
http://en.wikipedia.org/wiki/Similar_triangles#Similar_triangles
BTW: in this problem you are assuming that the sum of the angles of a triangles is 180 degrees. That is only true if the Pythagorean Theorem is true.
That wikipedia article tacitly assumes it is discussing euclidean geometry and not some other geometry. the phenomenon of scaling is peculiar to the euclidean case. even there, it must be proved that the two properties are equivalent, equal angles and proportional sides. Moreover the meaning of the concept of proportional sides must be defined. Remember that there are no real numbers in euclid, so it is meaningless just to say the lengths of the sides are proportional. euclid does have a concept of "equal area" without using numbers, by considering two figures to be equal (in area) if they are equidecomposable, or are the difference of two such figures. Thus I have used this concept above to define proportional sides without using numbers. If one does use numbers, one can prove the basic similarity result more easily, as i outline here.
just assuming the parallel postulate and nothing about areas, one can show e.g. that a line that bisects one side of a triangle, and is parallel to the base, also bisects the other side. This is the first case of the theorem on similarity.I.e. this implies the fact that a triangle with the same angles as another triangle, and with one side equal to half the corresponding side of the first triangle, in fact has every side equal to half the corresponding side of the first triangle. Thus the triangles are similar, in the sense of having proportional sides.
Next we prove the same result for triangles with the same angles and such that one side is 1/3 the corresponding side of the first triangle. Then we do it for triangles with the same angles, and one side any rational multiple of the first triangle.Then using the fact that rational numbers are dense in all real numbers we deduce the result for all triangles with the same angles, under the assumption of the archimedean axiom for our geometry.This proof does not use pythagoras, but of course uses the equivalent parallel postulate. I attach it from my class notes from 2007.
